Author Topic: Spec summary PDF  (Read 4896 times)
Spec summary PDF
« on: August 27, 2018, 05:49:06 PM »
There used to be a PDF on this site with a summary table of most if not all the torque and valve specifications one would need for most K-bike work. It disappeared from this site apparently because some of the values were incorrect. I'm wondering if anyone would be interested in resuscitating that document, which I found incredibly helpful and still use despite some of the values being 'off'. I'd be glad to recreate the document in Excel, copying the existing format, and repost as PDF if someone would help by correcting any of the data that's incorrect.
Re: Spec summary PDF
« Reply #1 on: August 27, 2018, 06:39:52 PM »
TEMPORARILY REMOVED -- ZIP of Excel file with specs and PDF version of the same attached.
« Reply #2 on: August 27, 2018, 07:23:21 PM »
I believe the reason this torque table disappeared from the site might have been that the values marked by the red rectangle in the attached image are reversed. The lower torque value belongs to the upper pinch bolt; the upper value belongs to the lower bolt. Somebody might have broken a fastener and screamed bloody murder. I seem to recall the echos. There was no telling if other transpositions or typos were in the table unless they were all verified by somebody; the table disappeared. Compare values with those in second image from the BMW workshop manual.
From the deleted table:
From the factory workshop manual:
  • 1995 K75 89,000 miles
« Reply #3 on: August 27, 2018, 07:51:33 PM »
Thanks for the heads-up Laitch.  I didn't realize the mistakes.
The values came from the original table but I haven't validated them against the OEM specs.  The conversions should be accurate because they are calculated.  I'll go through the table this week and update it.  Meanwhile I can remove the attachments until that validation work is complete.
Offline blackie1
  • christchurch nz
« Reply #4 on: August 28, 2018, 02:25:38 AM »
good on ya Rob
i for one will  find it handy
nailed to my garage wall for quick reference,
I already have the perfect spot for it, it can nestle between posters of the Britten V1000 and the voluptuous samantha fox (i'd rather ride the Britten)
voluptuous ...... lol it just rolls off the tongue doesn't it
  • 1991 K75RT naked 67,000kms
Offline thecableguy
« Reply #5 on: August 28, 2018, 09:42:39 AM »
... the voluptuous samantha fox ...
 :useless
  • Madison, WI USA
  • 86 K100RT - Brünhild
Offline thecableguy
« Reply #7 on: August 29, 2018, 10:13:03 AM »
Ok, I'll stop hijacking this thread now...  But what torque value is on that zipper?
  • Madison, WI USA
Offline bocutter Ed
« Reply #8 on: August 29, 2018, 12:45:04 PM »
I don't think you can torque a busted zipper ...
  • Toronto, Canada
