I'm having a mystery issue with k75.
Had a blown fuel pump, replaced the whole kit, all the lines, everything except the injectors and fuel pressure regulator.
Cleaned the injectors via compressed air and petrol (there was rubber type of slushy in the fuel rail) They seem to spray ok, spark plugs are all showing the same, so injectors might be bad, but equally bad then :D So not like one cylinder works and others don't.
replaced the spark plugs, air filter, maf seems to work ok aswell.
Power wise the bike pulls strong, the TPS has been set correct, same issue with it unplugged aswell.
Fuel pressure is held at steady 36-38psi.
Fan kicks on so the temp sensor works.
I have not taken all the throotle bodies apart, but whilst spraying the whole engine with brake cleaner it did not react, so it should not be it then?
Pretty much whilst driving the bike has 1 second delay and then it pulls strong.
What am I missing?
<iframe width="560" height="315" src="
https://www.youtube.com/embed/9EUpUEltitg" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
