Author Topic: ABS sensor question  (Read 4788 times)
Offline beemuker
ABS sensor question
« on: August 08, 2018, 09:08:41 AM »
Installed a used right front rotor as mine was warped. Now the trigger gap
is .006 in.  Clymer specs it at .014 - .025.  The ABS seems to be working fine, should I try to source the  .012 shim, BMW 34 51 1 458 408., now, or can I wait until I need some other parts.
  • Panama City, FL
Re: ABS sensor question
« Reply #1 on: August 08, 2018, 09:17:58 AM »
I would be tempted to  let sleeping dogs snooze as long as the ABS system is happy.  I have found that removing the front sensor can damage it since they seem to corrode into the bracket.  In any event, don't buy any shims yet.  I have a bunch of them here someplace and would be happy to send you one if you need it.
Offline beemuker
« Reply #2 on: August 08, 2018, 09:38:32 AM »
Thanks. I'm in the "if it works, don't fix it ,camp too" The problem I could see would be if the ring expanded enough from heat to contact  and ruin the sensor. I would like to have the shim handy if and when I decide to install it. Would be happy to send a SASE with some $ if you could locate the shim.
  • Panama City, FL
« Reply #3 on: August 08, 2018, 11:16:29 AM »
Can't look today, but will before next week.  I already have a stamp and an envelope.
