Author Topic: Adding a resistor to reduce the flashing speed of indicators  (Read 4943 times)
Offline dale
« on: August 02, 2018, 09:08:11 PM »
I am about to add in resistor(s) in parallel between ground and the positive wire coming from the relay box which goes to an indicator.
Ive been reading a lot of different methods for rectifying the old indicator speed but havent seen this.
I will add a couple of resistors per indicator in parallel as i am anal and want to avoid overheating.
Someone stop me before i try this tomorrow
  • Melbourne
  • CB250, BMW K1100LT
Re: Adding a resistor to reduce the flashing speed of indicators
« Reply #1 on: August 02, 2018, 10:55:05 PM »
Although you haven't explicitly mentioned it in your post, should we assume that you are replacing the incandescents with LEDs.
If so, then don't use ballast resistors as you intend.  They may work for Jap bikes with a simple flasher relay but they aren't great for BMWs with a complex flasher module.  There are three techniques to slow down the hyperflashing:
1. cut a trace on the PCB of the flasher module to prevent hyperflashing
2. add a parallel capacitor to the circuit in the flasher module
3. modify the flasher module to make a LED friendly DIY version
Offline kioolt
« Reply #2 on: August 03, 2018, 12:03:56 AM »
If you add a couple of resistors to each indicator make sure that you double the resistance of the individual resistors used.
Offline dale
« Reply #3 on: August 03, 2018, 12:12:30 AM »
I am actually just using normal 6watt globes for the indicators and had planned on adding Power resistors.
I have accounted for adding the resistors in parallel.
Thanks for the links, RBM. I have read links 1 and 3 before but haven't seen the Maru labs one.
Translating and reading now
Best regards
  • Melbourne
« Reply #4 on: August 03, 2018, 12:27:20 AM »
I have been searching for an English version of the Maru labs link but have not had luck.
Try here, click Downloads then scroll down the list. The English version is next to the last selection.
Offline dale
« Reply #5 on: August 03, 2018, 12:30:26 AM »
thanks Laitch i ended up using google translate
  • Melbourne
Disagree Disagree x 1 View List
Offline dale
« Reply #6 on: August 05, 2018, 05:22:29 AM »
Adding the two resistors in parallel is now working. I'll update the post if it fails
  • Melbourne
« Reply #7 on: August 05, 2018, 08:29:26 AM »
This is now working. $3 and 15 minutes to connect. I'll update the post if it fails
How about verifying what worked right now, Dale?
Offline dale
« Reply #8 on: August 05, 2018, 04:59:39 PM »
Adding 2 separate resistors in parallel, in order to reduce the speed of the indicators to 1 per second, Liatch.
  • Melbourne
