Author Topic: Using hydraulic lawnmower jack to lift up K100  (Read 16260 times)
Offline Ironwrx
  • I thought I was wrong, but I was mistaken.
« on: July 31, 2018, 03:03:29 PM »
Hi. Wondered if any of you have used a hydraulic lawnmower jack to lift and service your K bike? I assume if it were feasible, I'd have to put blocking in certain areas to lift with. Just didn't want to put pressure where I shouldn't when I'm changing tires.
* Mower Jack.jpg (116.82 kB . 768x576 - viewed 1325 times)
  • Westminster West
  • 1985 K100 83 Type 0511
- Jon
Offline RobP
Re: Using hydraulic lawnmower jack to lift up K100
« Reply #1 on: July 31, 2018, 03:31:39 PM »
I have the same jack and have done so.   I put a steel plate across the two rubberized bars and put some leveling blocks on the plate.  I did not find it to be very stable by itself, so I put a 2x6 under the jack and sticking out on either side and used some motorcycle tie-down straps for additional stability.
I re-positioned the jack fore and aft as needed to take off the wheels one at a time
  • Driftwood, TX
  • 1985 K100RS
Offline Ironwrx
« Reply #2 on: July 31, 2018, 03:42:26 PM »
Hi RobP. thanks for your input. That's what I figured I'd have to do. My question is: where are the "safe" points to place the leveling blocks so as to not hurt the engine?
  • Westminster West
- Jon
Offline RobP
« Reply #3 on: July 31, 2018, 03:47:22 PM »
I put blocks across the main oil sump and the transmission, depending on whether I wanted to lift the front or back wheel.
(I first removed the belly fairing and the bracket on my bike.)
  • Driftwood, TX
  • 1985 K100RS
Offline Ironwrx
« Reply #4 on: July 31, 2018, 03:49:47 PM »
I hear you, I'm hoping to lift the whole bike as I need to take both wheels off and get new tires mounted at the shop.
  • Westminster West
- Jon
Offline Jethroww
« Reply #5 on: July 31, 2018, 06:57:25 PM »
Hi, this is from Chris Harris, Could possibly  modify for your set up?
You can see him using it in some of his videos.
Jethroww
  • Ontario,Canada
  • BMW 1974 R75/6, BMW 1988 K75s 1989 BMW K100RS-SE Past: 1972 Norton Commando Combat
« Reply #6 on: July 31, 2018, 07:23:44 PM »
Hi,  I had such a lift once and devised a set of outriggers to add stability to the K-bike.
http://www.k100-forum.com/t2088-motorcycle-jack-versus-motorcycle-lift#18167
The tie-off points were between the bracket on the jack, over the seat and onto the rear bracket on the jack.  It was a very stable setup.
Offline Ironwrx
« Reply #7 on: July 31, 2018, 08:20:23 PM »
Something that all these replies have missed is the basic question that I have asked; where can I lift my K100 without damaging the engine? Can I put all of the bike's weight on the oil pan? I'm not worried about jack stability, (I'm a weldor/fabricator and can make jack stable). Just want to know what part of the bike I can lift against. Thanks.
  • Westminster West
- Jon
« Reply #8 on: July 31, 2018, 08:27:41 PM »
i have seen bricks on those jacks... the way i take both wheels off is to put it on the center stand... take the rear off... put a jack stand under the fork and take the front off... the center stand holds it up and the jack stand keeps it balanced...
Offline Ironwrx
« Reply #9 on: July 31, 2018, 08:32:14 PM »
Thanks  j o But can you answer the one answer that seems to be eluding me: can I lift the bike by jacking up against oil pan?
  • Westminster West
- Jon
« Reply #10 on: July 31, 2018, 08:45:49 PM »
i read the question as being if any of you have used a hydraulic lawnmower jack to lift and service your k bike...
looks like you gotts questions about your question...
the answer is... you caint hurt that 3 screwed oil hatch with that jack... that hatch is stout...
« Reply #11 on: July 31, 2018, 09:26:02 PM »
I'm curious to see a hydraulic lawnmower.
« Reply #12 on: July 31, 2018, 09:36:10 PM »
I have a made a service box a la Chris Harris and to get the bike onto it I strap down the front wheel then jack the bike up using a piece of 4x2 across the center stand mounting bolts, the jack itself is just a normal scissor jack from my car, when the bike is high enough I slide the box underneath the main flat part of the engine so it is supported all the way across the length of the engine block.
« Reply #13 on: July 31, 2018, 09:42:51 PM »
I would say the  engine is plenty strong enough.  I support my bike on a stack of 2x8 chunks under the oil pan when I do spline lubes.
Offline Ironwrx
« Reply #14 on: July 31, 2018, 10:57:13 PM »
I'd like to see one too. The tree service uses hydraulic pole saws to nut limbs from their hydraulically operated bucket truck.
ALRIGHT!! A HYDRAULICALLY OPERATED JACK FOR LIFTING LAWNMOWERS!! (Is that clear enough?) LOL
  • Westminster West
- Jon
« Reply #15 on: July 31, 2018, 11:03:05 PM »
i withdraw my answer... i though it was a pneumatic jack used to lift hydraulic lawnmowers...
Offline Ironwrx
« Reply #16 on: July 31, 2018, 11:09:36 PM »
Thanks to all of you for your words of wisdom. I'm beginning to realize that the K100 is not just a typical motorcycle. Jacking up just any bike by its engine would certainly not be a good idea. I've worked on cars and trucks for almost 40 years, and if I  tried to jack against the oil pan of any of those, there would certainly be damage.
  • Westminster West
- Jon
Offline Ironwrx
« Reply #17 on: July 31, 2018, 11:15:10 PM »
j o - You withdraw your answer? BTW, I wasn't asking about jacking on the oil hatch, I was origionally just asking WHERE I could jack on the bike.  I thought you were saying it was ok to jack up a K100 by its oil pan??? now I'm really confused! go back to my first post on this topic, if you look at the picture, it will clarify what I am talking about.
  • Westminster West
- Jon
« Reply #18 on: August 01, 2018, 07:11:59 AM »
On the contrary, It is quite possible to jack the bike up using the oil pan as the base.  That part is very strong.  I do it all the time.   I'd only suggest using padding such as plywood between the oil pan surface and jack to protect the finish.
« Reply #19 on: August 01, 2018, 07:46:59 AM »
All I can add is that if you lift on the oil drain plug you need to counter bore the piece of wood a bit to compensate for the plug which stands proud of the oil pan.
« Reply #20 on: August 01, 2018, 08:19:23 AM »
soft wood will deform and conform to that drain plug... woodnt it...
« Reply #21 on: August 01, 2018, 09:01:05 AM »
SPF dimensional lumber is just hard enough that the bike wobbles on the drain plug.  Not a lot, but wobbles nonetheless.  Annoying...
Offline beemuker
« Reply #22 on: August 01, 2018, 09:14:20 AM »
I have a similar jack,. I just take off the belly pan, center stand it and remove the rear, put one end of the bars under the oil pan , jack a little to get the front end up. and remove the front. the jacking surface has rubber on it and has not scratched or damaged the oil pan.
  • Panama City, FL
« Reply #23 on: August 01, 2018, 09:34:51 AM »
You're too far north for Brazil nuts. Are those walnuts, butternuts, hickory nuts or hazel nuts?
« Reply #24 on: August 01, 2018, 11:11:09 AM »
See this post about that -- Poor Mans' K-Bike Jack
http://www.motobrick.com/index.php/topic,5254.msg32470.html#msg32470
In the meantime I forked out the $300 for a Harbor Freight motorcycle lift and highly recommend it.
Tags: jack
