Author Topic: Tube Tires  (Read 8427 times)
Offline Grant
Tube Tires
« on: July 28, 2018, 10:30:11 PM »
I searched and can't find a definitive answer, can I use a tube type tire on my 1984 k100? Or are the rims designed only for tubeless tires? I am looking at some Shinko 705 tires.
  • Abbotsford BC Canada
  • 1984 K100 0005895
Re: Tube Tires
« Reply #1 on: July 29, 2018, 12:28:59 AM »
Most manufacturers stress using a tire with its appropriate rim style, but there are dozens—maybe even hundreds of anecdotal posts on several forums regarding the degrees of success that tube-type (TT) tires have when mounted on tubeless (TL) rims—classic K-bike rims included. What would a definitive answer look like to you, Grant?
Offline Skunky
Re: Tube Tires
« Reply #2 on: July 29, 2018, 04:11:54 AM »
can I use a tube type tire on my 1984 k100?  Some people have!
Or are the rims designed only for tubeless tires?  Yes they are but....Some people have!
I am looking at some Shinko 705 tires     Which are tubeless and will fit your rims without tubes
https://www.ebay.co.uk/itm/371549099240
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
Re: Tube Tires
« Reply #3 on: July 29, 2018, 08:31:03 AM »
they say the tubbe valve stem will be compromised where it attaches to the tubbe because it will not fit the valve stem hole in the wheel and will eventually blow doo to chafing which is generally a combination of friction and moisture as it pertains to the tubbed tubbless application...
Re: Tube Tires
« Reply #4 on: July 29, 2018, 08:54:32 AM »
The two in your link are but they aren't an optimal fit for an early K100 or its stock Y-spoke rims—especially the wide one. Other 705 sizes closer to K-bike stock diameter and width are TT.
Offline Skunky
Re: Tube Tires
« Reply #5 on: July 29, 2018, 10:13:04 AM »
I see
  • Derby GB
Offline Skunky
Re: Tube Tires
« Reply #6 on: July 29, 2018, 10:21:53 AM »
Always difficult getting square pegs in round holes.  :dunno
  • Derby GB
Offline Grant
Re: Tube Tires
« Reply #7 on: July 29, 2018, 11:01:03 AM »
Thank you for the replies everyone.
From what I can gather, the definitive answer is that my bike has rims that are designed to use tubeless tires, therefore I should be looking for tubeless tires. "some people have used tubes" is not very definitive, especially in the absence of very little disclosure on the consequences or final outcomes.
I want a beefier look for my tires on my scrambler build, as I have seen on numerous pictures of builds. There are several tire sizes / combinations that may work? I am still researching this. Any advice or positive experiences on this would be greatly appreciated. (Pictures would be nice).
My goal is to mount some tires that fit with the scrambler look and are safe to use, (if such a combination exists without some compromise).
  • 1984 K100 0005895
Offline Skunky
Re: Tube Tires
« Reply #8 on: July 29, 2018, 12:12:20 PM »
DJewen has put some Chunky Tyres on his recent build take a look and ask him.
http://www.motobrick.com/index.php/topic,10875.msg94227.html#msg94227
  • Derby GB
