Author Topic: SPAL FAN replacement: Is this the one?  (Read 24489 times)
Offline bizzaro
  • co pilot
« on: June 23, 2018, 07:15:47 PM »
https://www.amazon.com/Spal-30100402-Puller-6-5In-15Amp/dp/B01LXF8FWE/ref=sr_1_3?s=automotive&ie=UTF8&qid=1529794718&sr=1-3&keywords=spal+cooling+fan+6.5
Yep, my fan is fried! What a piece of crap. It is the classic melted brush housing.  How can BMW overbuild the motors so well and use shit for auxiliary parts. WTF. Maybe this  should be posted in D.P. But I needs to know. Trip coming up in three weeks so I gots to "get er done". Those that have made the transition, please confirm.......or better solutions?
  • Vermont
See Ya in the Twisties,
 Bizz
Re: SPAL FAN replacement: Is this the one?
« Reply #1 on: June 23, 2018, 09:11:49 PM »
Looks like what I used.
Offline bizzaro
  • co pilot
« Reply #2 on: June 23, 2018, 09:26:20 PM »
Thanks Gryph. Just wanted some confirmation before I put down the cash.  I was checking my temp sensor at the stand pipe.  When I got the radiator out, I thought I would try and clean/oil the fan . Glad I did. When I got the motor cover off the fan, the positive brush fell out. All brush holders/housings were melted into shit.  The last time I tested the fan it was fine!
  Never done any plastic welding. Would a hot glue gun work?  I mean isn't that just plastic? Or do you just use a soldering gun?
  • Vermont
 Bizz
« Reply #3 on: June 23, 2018, 10:01:23 PM »
https://www.amazon.com/gp/product/B075FSCHZC/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
This is what I got for my '95. Pretty much a direct replacement, solder the wires, works just fine, and it's only $45.
1995 K1100LT 0302044 (R.I.P)
Offline bizzaro
  • co pilot
« Reply #4 on: June 24, 2018, 08:37:19 AM »
Scott,
Thanks for the link.  I am a bit leary as it looks like the the Bosch motor that was in the bike in the first place. I assume this is an upgraded plastic that holds the brushes in place.  I know the fans aren't designed for constant use, but mine was fried. That is a substantial savings, and no mounting issues.
  • Vermont
 Bizz
« Reply #5 on: June 24, 2018, 02:09:04 PM »
I figured if the original one lasted near 20 years, that's not a bad run for an electric motor in the environment that it is located in.
Offline stokester
« Reply #6 on: June 24, 2018, 02:37:19 PM »
I haven't had to replace mine yet but bought a spare from https://www.tills.de/product-112-113-158.html.
Although it looks like they are currently out-of-stock, for me the shipping was fast and the quality is superb.
  • Yorktown Virginia
Offline bizzaro
  • co pilot
« Reply #7 on: June 24, 2018, 03:50:01 PM »
stokester, wow, now that's a fan.  But it is more than I want to spend.  Well not as much as BMW/Bosch fan that was in there. $350,  :yow  thanks for the link. Nice to have options.
  • Vermont
 Bizz
« Reply #8 on: June 24, 2018, 03:58:47 PM »
I blew mine about 19 years ago, total brush meltdown. I was horrified by the new price, and second hand price wasn't much better. I didn't like the design of the motor, so I decided to go none OEM. I didn't know about Spal fans so I went to one of the car supply places after seeing an ad for 50% off in a cattledog and bought a Davies Craig fully sealed fan, the smallest that they had. From memory I think it was around $35.00 - $40.00. I ended up cobbling the two housings together and used the OEM blades. It's never missed a beat.
Offline bizzaro
  • co pilot
« Reply #9 on: June 24, 2018, 04:30:01 PM »
Hey Martin,
Yea, I have considered using "others" fans.  I am a kiss (keep it simple stupid) kinda guy though. The less labor,money, and time invested the better.
  • Vermont
 Bizz
« Reply #10 on: June 24, 2018, 05:04:01 PM »
Bizz I cobbled the two together by cutting off the OEM plastic motor support arms. And after pulling the blades off the DC (Davies Craig) fan, I placed the DC housing over the OEM housing. I found that one off the many concentric rings that made up the DC hosing lined up with the OEM's singular ring. I cut off the outer surplus DC mounts and rings. I then made up four "C" shaped clips (1/2" stainless Bandit strap) that went over the outer DC ring and onto the OEM ring. It then pop riveted them together from the inside out so as not to interfere with the blades. As a precaution I also put flat washers over the ends of the rivets. I had to space the DC fan motor out 10-12mm from the DC mount to clear the radiator. This was done using longer screws and a bit of PVC plumbing pipe that lined up with the DC motor. The advantage the DC one has is that it is fully sealed. I do believe that if you look around there are fully sealed brushless motors around.
Good luck regards Martin.
Offline bizzaro
  • co pilot
« Reply #11 on: June 24, 2018, 06:25:32 PM »
It has occurred to me that I my not need a fan at all?  :dunno2: I mean I almost always shut off the bike if I am stopped in traffic.  And with the fan out of there, the airflow must be vastly improved. We are due some heat this week, so I will be monitoring my engine temps with scrutiny! Now that I have a working temp guage thanks to fellow bricker, JJJ. :2thumbup:
  • Vermont
 Bizz
« Reply #12 on: June 24, 2018, 07:31:16 PM »
What happens when traffic is moving at four miles an hour—not that there's any traffic where you live. Who knows though? Someday you might find yourself in Montreal, or Morrisville. :giggles Get a fan, you cheapskate. Mercedes parts not good enough for you?
« Reply #13 on: June 24, 2018, 08:19:54 PM »
Here is a thread on easily retrofitting the Spal fan to the brick.  If you have an 80 grit sanding disc and a pop riveter it takes about an hour after the old fan is removed from the radiator.
Here is the link to the procedure I used when I replaced my fan that had totally melted it's brush holders.  Go to reply #18 December 20, 2014  There is a good description and nice pictures.
http://www.motobrick.com/index.php/topic,4313.0.html
Offline bizzaro
  • co pilot
« Reply #14 on: June 25, 2018, 10:47:30 AM »
thanks Gryph. will order my fan today
  • Vermont
 Bizz
Offline bizzaro
  • co pilot
« Reply #15 on: June 25, 2018, 11:00:31 AM »
Scott, are you sure you got a pull fan?  The Bosch number on my dead fan ends 305.  I think in one of my search's, I found both motors offered, one was a push, and the other a pull fan, and the last three numerals where off by one number and the 305 was a pull fan. And the advertisment says blower?
  • Vermont
 Bizz
« Reply #16 on: June 25, 2018, 11:01:49 AM »
I went without a fan for a couple years, though I did get a little nervous at times.  Gotta admit it was nice not having the heater kick on when I least wanted it  :hehehe
« Reply #17 on: June 25, 2018, 02:04:32 PM »
That was the one that I ordered and installed, and it pulls......  I did check the rotation before I did any soldering for installation.
Offline bizzaro
  • co pilot
« Reply #18 on: June 25, 2018, 03:29:26 PM »
Thanks for the confirmation. I may go that route as it is the simplest. RnR, :2thumbup:
  • Vermont
 Bizz
« Reply #19 on: June 25, 2018, 06:03:00 PM »
It's a DC motor.  Reverse the leads to reverse the direction.
Offline bizzaro
  • co pilot
« Reply #20 on: June 25, 2018, 07:04:17 PM »
Yes Robert, I had thought of that, just change the wires around if it is pushing, but the way the brushes are mounted for the rotation of the armature would not be correct and may be problems down the road.  Scott did confirm it is a pull fan anyway.
I really like the sexy one that stokester linked, but it is about $130 U S before shipping. Almost double the
SPAL fan.
  • Vermont
 Bizz
Offline stokester
« Reply #21 on: June 25, 2018, 09:33:56 PM »
Yes Robert, I had thought of that, just change the wires around if it is pushing, but the way the brushes are mounted for the rotation of the armature would not be correct andd may be problems down the road.  Scott did confirms it is a pull fan anyway.
SPAL fan.
The Tills uses the SPAL but also has a very well made mounting bracket and uses the proper connector.  I bought it last year at a total cost of about $130.  Yes it is more expensive than just replacing the fan but it appears to be a plug and play that will install without modification and last the remainder of my K75's life.  For me it's worth the extra money and I help a business that is supporting my favorite mount.  No stones thrown at others who do it differently.
I have not installed it yet but having just passed the 75K mile mark on my '93K75S and having read many stories of the fans failing before reaching 100K it will be replaced this winter if not before.
  • Yorktown Virginia
Offline bizzaro
  • co pilot
« Reply #22 on: July 13, 2018, 09:12:30 AM »
Oops. To conclude this thread, I went with the Spal Fan conversion. Works GREAT, :2thumbup: Also added a manual over-ride switch for the fan? Highly recommended . I used the manual switch a lot on a trip  in 80 to 95 degree weather this past weekend in stop n go and construction traffic.
  • Vermont
 Bizz
« Reply #23 on: July 13, 2018, 05:55:31 PM »
+1 Adding an override switch allows you to run the fan in traffic before it overheats. It also gives the added benefit of being able to test that the fan is working.
« Reply #24 on: July 13, 2018, 06:24:38 PM »
Not to split hairs here, Martin, but the system is designed to activate the fan before the engine overheats. It seems to work on my moto. That's why in a fully-functioning system, the fan activates before the temperature warning light is lit. An override switch keeps the fan from cycling in hot weather or traffic operation—which can be bothersome to some riders—besides allowing the rider full control over its operation.
I like the fan's cycling; it has old world charm. Of course, I'm not riding in the desert, or heavy traffic very often.
