Author Topic: Motronic ground wire?  (Read 3632 times)
Offline BlueK11LT
« on: June 10, 2018, 04:42:34 PM »
Today ive had to tape up a few inches of the wiring leading into the large motoronic plug on the K1100LT because the original sheathing was cracked and split quite badly.
There is a few inches of brown/blue wire sticking out of the wiring with no connector on the end of it.
Is this the ground wire for the motronic that should be connected to the spade terminal on the motronic just above and to the left of the centre of the photo?
thanks
  • North East England
  • 1997 K1100LT,1977 Kawasaki Z650B1,1991 Honda ST1100
Re: Motronic ground wire?
« Reply #1 on: June 10, 2018, 05:13:38 PM »
Yes, that would be a static ground for the case of the motronic.
1957 K1100LT 0302044 (R.I.P.)
Offline BlueK11LT
« Reply #2 on: June 10, 2018, 05:36:31 PM »
Thanks
strangely though,but that wire has been disconnected I think most of the time ive owned the bike but doesn't seem to have caused any issues.
« Reply #3 on: June 10, 2018, 06:18:18 PM »
it will save the motronic if you are hit by lightening riding the squall line...
« Reply #4 on: June 11, 2018, 08:17:04 AM »
Thanks
It doesn't serve any function directly related to the electronics operation of the bike. If you notice the mounting of the motronic it is slightly vibration isolated with rubber mounting so it then has no electrical bonding to the frame. That's the purpose of the wire, to provide a static discharge point for the metal case, nothing more. I've found mine disconnected a few times myself, I just reconnect it and move on.
