Author Topic: starting/ idling issues  (Read 4862 times)
Offline Tykilgro
« on: June 08, 2018, 11:44:32 AM »
Hey There I just purchased a 85 k100 here this past month that has been sitting for two years. Needed a new fuel pump, which i replaced, and i got it to run but barely. It ran but rough, wouldnt idle right without the choke, then shut off and wouldnt start back up. I then followed up with replacing the spark plugs to see if it wasnt firing right. didnt fully fix it. After spraying some starter fluid in the air box i got it to run but it still feels weak and wont start without assistance from a can. I checked to injectors and they are sending fuel.
Also it smokes like a sum bichhh too.
What should i look for or try next to get running properly.?
  • North Alabama
  • K100
Re: starting/ idling issues
« Reply #1 on: June 08, 2018, 12:00:28 PM »
Any neglected bike should get a new fuel filter, the spark plug wires should be verified that they are attached to the correct coil, the fuel tank's hoses should be replaced, the tank vent hose—or vent port, if it doesn't have a hose—should be checked to be sure it isn't clogged, the air box, air filter and exhaust pipe should be checked for restriction and the z-tube from the crankcase to the air box should be checked for leaks. That's where you can begin.
Please post a photo or two of the bike. You have the model of your bike in your profile; put its year in there, too. Then it will show up in every post you make and respondents will know what is being discussed if you neglect to put it in the post.
Offline beemuker
« Reply #2 on: June 08, 2018, 05:56:23 PM »
Also it smokes like a sum bichhh too. It is mind boggling the harm caused by people not properly storing machines. make sure you a are using a strong battery too.they don't run well with a bad battery.
  • Panama City, FL
« Reply #3 on: June 08, 2018, 08:32:02 PM »
id spray it down real good with pb blaster... not the can... the 5 gallon bucket of the liquid stuff... id put it in a bug sprayer and soak everything except seat and grips...
Offline tg4360
« Reply #4 on: June 09, 2018, 04:47:05 AM »
As a quick check, rough idle could be the z hose or the fuel pressure regulator.
Goldmine here:
http://www.ibmwr.org/ktech.shtml
Tony G
'79 XS750 "The Triple"
'72 A65T "The T-Bolt"
'68 B25 "The Blue Bike"
Offline alabrew
« Reply #5 on: June 09, 2018, 12:35:06 PM »
Welcome from a fellow Alabamian. I too have a difficult to start '85 that sat outdoors for several years. Air leaks are what I am finding to be the cause and I too am hunting them down. Runs GREAT once warmed up, but takes a few minutes to get there. I recently tried wrapping the intakes with electrical tape and that helped a little. Looks like those are next to be replaced, I've done just about everything else. Hard to believe those 33 yr. old parts need replacing.  :giggles
Smoking is a "characteristic" that can be avoided by parking on the center stand.
Work your way through the diagnostic tree and you will get there.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
