Author Topic: K75 Radiator Cowl won't fit stripped down RT?  (Read 6417 times)
Offline bluebossa
  • K75 and R65 Owner
« on: June 07, 2018, 04:42:10 PM »
Does anyone know why a standard K75 standard front radiator cowl wouldn't fit a K75 RT?
I took the fairing off the RT and thought it would be a straight fit, but won't go near.
Is the RT radiator bigger or some other reason or are there more than one version of the Cowl for different years of K75s.
Bike and Cowl pictures attached. Cowl was scruffy but just assumed it would fit, after a repaint of course.
  • UK
  • K75C
Current Bikes: K75 (C) in the UK (1986), R45 (1981)
Former Bikes:  K75RT, K75S, R850R, K1100RS, Dnepr MT10-36, R1200GS, K100, R100T, R100RT.
BMW R45 and K75 Blog
Re: K75 Radiator Cowl won't fit stripped down RT?
« Reply #1 on: June 07, 2018, 04:54:32 PM »
The K75RT have a K100 fuel tank which is different from the other K75 models...that's the reason.
Offline bluebossa
  • K75 and R65 Owner
« Reply #2 on: June 07, 2018, 11:48:03 PM »
Well scupper me timbers! OrvsomeOr so similar who'd have thought that...
Now wondering if a K100 cowl is a thing... Will check thanks for the knowledge.
  • UK
  • K75C
« Reply #3 on: June 08, 2018, 04:38:41 AM »
To make the confusion complete, the naked K100II have a K75 fuel tank.
Offline gone_ape
  • 94 K75RT (Now Standard)
« Reply #4 on: June 09, 2018, 08:23:18 PM »
Perhaps this may help..........
http://www.motobrick.com/index.php/topic,10877.msg94288.html#msg94288
If you wanted to mount that cowl type, besides all the obvious smaller radiator stuff, you would need to fabricate some mounting pins to the tank (or make bracketry to suit) to support the front of the cowl...I had an RT and converted it to standard and had to do just that..
Alternative would be to obtain aftermarket K100 side cowls (theres a German custom parts shop that sells these) but their looks are subjective..
https://cafe4racer.eu/en/bmw-side-covers/564-bmw-cover-of-radiator-righr-side-46632308104.html
  • Austin, TX
Offline bluebossa
  • K75 and R65 Owner
« Reply #5 on: June 10, 2018, 02:46:04 AM »
Thanks, I noticed the noticed the custom parts. Guess they just paint up and are only side pieces not a full cowl?
With the info above does a K100c cowl exist and fit the RT?
Comments on other threads say they are rare, but does that part exist...?
  • UK
  • K75C
« Reply #6 on: June 10, 2018, 04:28:24 AM »
You don't see this parts on ebay everyday.........................
It could be a flimsy fit with the smaller K75 rad, maybe you could add some rubber or similar at part #11
on each side.
Radiator cowl
Motorworks maybe have some of the parts: Cowl parts
Offline bluebossa
  • K75 and R65 Owner
« Reply #7 on: June 11, 2018, 03:25:44 PM »
Thanks Inge - I'll give Motobrick a ring, but I'm guessing they won't have it as they are so scarce from what I can see.
  • UK
  • K75C
