Author Topic: ignition switch: green/gray jumper okay?  (Read 7646 times)
Offline schrocketeer
« on: June 01, 2018, 12:49:43 AM »
To get my 1985 K100RT taillight working, would there be a problem making a jumper between the green and all gray wire in the ignition switch?
I tried it with a test wire in the shop and it seemed to work okay, but I may be overlooking a consequence.
  • North Alabama
  • 1985 K100RT very original
Ken
Re: ignition switch: green/gray jumper okay?
« Reply #1 on: June 01, 2018, 09:56:31 AM »
Have you power on gray/blue wire?
« Reply #2 on: June 08, 2018, 03:15:11 PM »
Following the links here, I ended up taking the key/ignition switch/lock apart, cleaned it up inside, and all is happy.
Thanks for the help. :-)
  • North Alabama
Ken
