Author Topic: 1987 k100RS forks?  (Read 6488 times)
Offline LITTLEWOLF
1987 k100RS forks?
« on: May 26, 2018, 06:16:15 PM »
Hi Guys,
im having trouble figuring out why I don't see the same parts on Bmw fiche. attached are some images. there is rubber bushing/bumper at the bottom of my dampener. any one else have this? I have a susspision that the previous over was dick.
I found some parts missing from the right fork that was present on the left fork. and some were arranged in the wrong order.
Im rebuilding this sucker so I want to make sure I get the right parts.
any thought and help would be great .
  • brooklyn ny
  • bmw k100rs
Re: 1987 k100RS forks?
« Reply #1 on: May 26, 2018, 08:21:07 PM »
Tell us what we're looking at in these three images. That bushing on the damper looks like part of a bicycle floor pump. :giggles Are you aware the K100RS Sport forks have differing parts on the left leg than on the right? Have you downloaded the K75/K100 2V manual from the Repair Guidance section here? There are a couple of fork styles that could have been used on your bike. It's fork chapter might clear things up for you about what you have on the table. Here is an illustration from it concerning Sport fork parts.
Offline LITTLEWOLF
« Reply #2 on: May 26, 2018, 08:37:01 PM »
Laitch!
Thank you for your reply.
what you're looking it the Dampener from the Right hand fork Stanchion .
I didn't know that there are different . but that presents another issue. they have all the same components from both forks, But when I opened them , the rubber on the bottom was in a different position one side was missing part 1, guid ring with notches. its weird.
I have the clymers manual. but im starting to understand its incomplete with info. ill look now at manual on this site see what I find.
Thanks!!!
  • brooklyn ny
  • bmw k100rs
« Reply #3 on: May 27, 2018, 04:21:29 AM »
The rubbers is non genuine...you missing the piston ring in the other end.
Looks to be a standard fork to me.
Offline timewolf
  • Little Wolf
« Reply #4 on: May 27, 2018, 09:44:02 AM »
inge,
Thanks you , i arrived to that conclusion .
on what end am i missing the piston ring? you mean on top ? the plastic sleeve that goes around that is split with notches?
thanks
Wolf
  • brooklyn
  • 1987 bmw k100rs
Holding it down since 79
Offline timewolf
  • Little Wolf
« Reply #5 on: May 27, 2018, 09:46:43 AM »
Added info these are brembo forks ... im reading on forums that people say they are crap, and i should get showa forks.. .thoughts?
  • brooklyn
  • 1987 bmw k100rs
Offline timewolf
  • Little Wolf
« Reply #6 on: May 27, 2018, 09:56:54 AM »
also, mine have two springs , and the diagrams have one  :nono
this is confusing. there isnt enough info in the manuals or on line.
 :dunno2:
  • brooklyn
  • 1987 bmw k100rs
« Reply #7 on: May 27, 2018, 10:04:46 AM »
The photos and diagrams are clear about what should be part of an assembly. You already know that your bike has had tinkering done to it. It's up to you to follow the diagrams, get the parts and assemble it.
There's plenty of information on line. It just takes patience to find it. Learning how to search efficiently is a skill you develop, just like reading a micrometer or vernier caliper. Look for stampings; measure tubes, etc.
« Reply #8 on: May 27, 2018, 10:54:37 AM »
Yes.
« Reply #9 on: May 27, 2018, 10:57:49 AM »
also, mine have two springs , and the diagrams have one   this is confusing.
The drawing shows one spring. But the parts list says 4 alltogether, 2 in each leg.
