Author Topic: FS or Trade - Type 1 Hard Cases  (Read 12986 times)
« on: May 24, 2018, 12:22:14 PM »
I've got a pair of Type 1 hard cases with white outer covers in good condition with bungee buddies on the top with only a few scratches, no cracks and no key locks.
Looking to trade with someone who has city cases or an aftermarket Sargent or leather Corbin seat in good condition.  I have a Sargent on my 93 K75S which is what it had when I bought it and my 94 has the stock seat.
Let me know what you have and if you need more pictures.
Re: FS or Trade - Type 1 Hard Cases
« Reply #1 on: May 24, 2018, 06:19:15 PM »
I don't need a third set of cases,  but offer still stands to trade a corbin for your stock seat....:)
Pictures of the corbin in my "refresh very 2.0" thread.   Link below.
« Reply #2 on: May 24, 2018, 07:42:15 PM »
Thanks for the offer but I want to retain the OEM seat.
Got a K&N from the other bike to throw in as well.  Just not a fan of K&N, we'll leave it at that.
« Reply #3 on: June 04, 2018, 07:49:06 PM »
Prefer to work out a trade for some city cases but am willing to sell the cases outright.
Make me an offer.
Offline mophead
« Reply #4 on: June 15, 2018, 03:48:11 PM »
Agree 100% with your take on K&N!!
  • Amarillo, TX
  • 95 K1100RS Formerly 86 K100RS & 91 K100RS
On the back nine of life
Offline gph67
« Reply #5 on: June 19, 2018, 01:34:34 PM »
I would be interested in hearing your reservations about K&N filters. I am skeptical as well but would like to hear other views on the subject.
My K75 had one when I bought it. I gave it a through cleaning but I have also read the OEM filters are good for a good long while. Thinking of changing out to original.
  • seattle
  • K75
« Reply #6 on: June 19, 2018, 02:03:39 PM »
This is my opinion only, there are lots of others on the web. I do not wish to create a pro-con thread on K&N, there are plenty out there.
The advantage of the K&N air filter is advertised as two-fold, never buy another and increased performance.
In addition to advice from others much more experienced than me such as Rob Fleischer (Snowbum http://bmwmotorcycletech.info ), my work at a Chevy dealership taught me that replacing an OEM paper filter is false economy.  While there were a number of instances where over-oiling the filter caused MAF problems there were also issues where the change in airflow caused a CEL which we would not diagnose without an OEM filter which frequently cleared the problem. Today's engines are engineered with many components, change the characteristic of one and you upset the balance.  Our engines are not so complex and many others have opined that the OEM air filter is more than adequate for the job for an extended amount of time.
There are many who have used these for years with no discernible problem but I always question that the increased airflow=performance  formula equals more dirt in my engine.  Anecdotal info for me was from a friend who runs a beef farm and maintains all his vehicles along with sending oil samples away for analysis.  The one engine he used a K&N had a significant increase in oil contamination causing him to return to the OEM paper filter.
As with many opinions you will have to decide which you choose to believe and follow, after all it's your motorcycle.  For me, as with most non-OEM substitutes, is it worth a few dollars saved over the long run?
« Reply #7 on: June 19, 2018, 02:08:23 PM »
My experience tells me that OEM filters have excellent air flow, are easy to shake out to clean, and last for tens of thousands of miles. Their composition is a design-element of the bike. I ride a lot of miles on maintained gravel roads. The bike runs well all season. I don't need more than that. I tap the bike's filter a few times on the shop floor at the end of riding season. There's a small pile of sand and debris there when I'm finished. The process takes about ten minutes with a naked bike, including introspection. :giggles
« Reply #8 on: June 19, 2018, 03:11:09 PM »
My K100RS 16V came with a K&N air filter.  When I took the airbox apart I found fine dust coating the inside.  Never found it with the OEM filters on my other bikes.
Immediately binned the K&N for a Mahle LX75 which cost $25 from Amazon.  The filters on these bikes should be good for at least 100,000 miles which is what the EPA regulations for emissions and fuel economy have required since the mid 1980's.
« Reply #9 on: June 19, 2018, 04:08:45 PM »
+1 OEM air filters are over engineered, I'm on my second one in 25 years 170,000 K's. I only changed it because I bought a spare and got sick of pulling it out and it still being fine. To clean I just tap and then run my shop vac over it.
Offline gph67
« Reply #10 on: June 26, 2018, 01:59:04 PM »
thanks for the input; OEM is the direction this K75 is going!
  • seattle
  • K75
« Reply #11 on: June 26, 2018, 02:39:27 PM »
Now that you're retired, three minutes work must seem like eternity. :giggles
« Reply #12 on: June 26, 2018, 04:01:23 PM »
Retired in name only. The Honorable Minister for Finance and Recreation has given me a large list of jobs. At the moment have just finished replacing the floor tiles in the uneven floored ensuite , replaced loo, replaced vanity, replacing vanity tiles today and going to get a replacement 900mm shaving cabinet. Bunnings sent the wrong loo the three onsite pictures show "S" trap one small part of the text said "P" trap it took four weeks to get it. So I went on Gumtree and bought an "S" trap locally I will have to sell the "P" trap. Spent half of yesterday at Ikea trying to sort out a problem with the shaving cabinet assembly. The whole batch was incorrectly manufactured and we bought the first one. They did however give us lunch vouchers while they went through a couple of more flat packs before coming to the conclusion they were all faulty. New batch maybe 4-6 weeks away, so we are going out today to look at alternative. If this is retired I want to go back to work. Due to renovations and weather the Brick has sat idle for the last two weeks. :hehehe
Regards a hysterical Martin.
Re: FS or Trade - Type 1 Hard Cases for Aftermarket Seat
« Reply #13 on: October 07, 2018, 04:37:38 PM »
 bmp
Still looking for an aftermarket seat to fit my stock-height 1994 K75S.
Let me know what you have.
Offline alexg
« Reply #14 on: October 07, 2018, 07:16:03 PM »
Hi:
Do not have anything for trade, but would be interested in adding bungee buddied (eyelets) to my cases. Where do you buy those?
Thanks,
AlexG
  • Michigan
Alex G.
« Reply #15 on: October 07, 2018, 11:44:31 PM »
Hi:
Thanks,
AlexG
took less than a minute to find this link.  Duckduckgo.com is your friend.
https://www.twistedthrottle.com/bungie-buddies
Offline alexg
« Reply #16 on: October 08, 2018, 10:49:44 AM »
Thanks for the info.
AlexG
  • Michigan
Alex G.
« Reply #17 on: October 08, 2018, 12:49:39 PM »
The rebellion against the Google Monolith is in full swing!
« Reply #18 on: October 08, 2018, 01:25:09 PM »
DuckDuckGo is my default - rebels unite!
« Reply #19 on: October 08, 2018, 04:55:22 PM »
Make me an offer.
I have a set of city cases with Krauser style locks (equivalent to the locks on your Type I cases) that I can sell. Cases are in fair condition; one of them has a crack in the plastic but does not affect its use.  I don't have interest in trading for your Type I cases.  Also, I'm in Canada so it would be a cross-border transaction, if you're interested.
« Reply #20 on: October 08, 2018, 05:43:23 PM »
Thanks for the offer Robert but I'm going to press forward to find an aftermarket seat and hope to sell or trade the side cases.
