Author Topic: Coil Pack Wiring  (Read 5381 times)
Offline lilau3
Coil Pack Wiring
« on: May 18, 2018, 04:26:42 AM »
Do I need the brown earth wires connected to anything? The coil packs are already earthed by the chunky wires going straight to the earth bolt in the transmission.  The part of the coils with the threads to mount the plastic cover all seem to be earthed.  I’m leaving the cover off for the minimal look.
I can’t remember but maybe those brown wires were for the auxiliary 12v output?
Cheers
  • Australia - Melbourne
  • 1988 BMW K100 LT, Vespa GTS300
Re: Coil Pack Wiring
« Reply #1 on: May 18, 2018, 05:34:13 AM »
The earth wires that is connected to the coils is non OEM, because of this the OEM earth wires is disconnected.
Offline lilau3
« Reply #2 on: May 18, 2018, 06:04:30 AM »
That would make sense. So I could unplug the silver braided wires and put the brown ones back on, that would clean things up. Although I’m assuming the previous owner did this to better earth the coil packs for some reason..... no problem, I’ll try both ways and check for any issues.
« Reply #3 on: May 18, 2018, 01:33:44 PM »
You don't need beefy grounding like that braid.  The ground is a safety ground; no current flows through it normally.  Therefore, either the OEM grounds or the aftermarket braid works.
