On the 1100's the center stand mount should already have some spacers. Depending on the bike, RS or LT, will determine if it has spacers or not.
On the LT the spacers are mounted between the stand mount and the transmission case, resulting in the bike rising up a tad bit higher for the taller profile LT tire.
It's possible a previous owner removed them? Are you running a stock tire size? Personally I am running a lower profile tire and removed the spacers so it is easier for me to put the bike on the center stand.
If you look at the parts fich's, you will see that the spacer is listed for the LT and mount bolts are a 10mm x 50mm bolt, the RS does not list the spacer and uses a 10mm x 40mm bolt.
The fiche doesn't list details about the dimensions other than for a 10mm bolt, and it is listed as a "washer", yet the bikes that use them(for center stand) also have 10mm longer bolts.....
