Author Topic: Front brake line/ABS sensor clip  (Read 2954 times)
Offline stokester
« on: May 10, 2018, 10:42:55 AM »
I recently replaced the brake lines with a Spiegler set on the '93 K75S.
The lines are more stiff and cause the clip on the front fender to pull out.  I think the clip itself is weak where it pushes into the fender causing it to pull out with a minimal amount of stress.
Although I could easily make a clip using zip ties I wanted to see if the clip was still available from BMW and cannot find it in the parts breakdown.
So does anyone know where it is or if it is listed?
  • Yorktown Virginia
Re: Front brake line/ABS sensor clip
« Reply #1 on: May 10, 2018, 12:13:55 PM »
Photo?
Offline stokester
« Reply #2 on: May 10, 2018, 12:44:20 PM »
Right side of front fender.
  • Yorktown Virginia
« Reply #3 on: May 10, 2018, 01:28:31 PM »
Part # 61 13 1 369 668
Offline stokester
« Reply #4 on: May 10, 2018, 02:54:04 PM »
Thanks much.
I was looking under fender and body parts, not brake.
  • Yorktown Virginia
