Author Topic: Impeller bolt  (Read 4063 times)
Offline Enfield
Impeller bolt
« on: May 07, 2018, 06:56:53 AM »
Hi. I am pretty sure that my waterpump impeller is loose.... sounds Like it:-/
I have the new type impeller and Shaft, but when I assembled it I didn’t use a torquewrench and loctite - so on it again.
 Question is - Can I just take front cover OFF and change bolt and thighten everything or do I risk damaging pumpgear ? Or do I need to take pump OFF entirely?
Anyone remember bolt size? Seems there is a special bolt for the impeller?
Regards
Chr
  • Copenhagen
  • K100 RS , K100, Royal Enfield Bullet
Offline Enfield
Re: Impeller bolt
« Reply #1 on: May 07, 2018, 07:24:51 AM »
Just to clarify... there is a weird whirring Sound when above 2.000 rpm ... when Returned to idle it stops?
 And when knowing the bolt was not set in loctite and correct torque I better check anyhow
Chr
  • Copenhagen
Offline Enfield
Re: Impeller bolt
« Reply #2 on: May 07, 2018, 07:55:10 AM »
@Laitch could you post the answer again? I Can see it in the headlines in Tapatalk but can’t opdn it? And on the forum it doesn’t show.
Regards
Chr
  • Copenhagen
Offline Enfield
Re: Impeller bolt
« Reply #3 on: May 07, 2018, 04:24:53 PM »
Took the cover OFF - but could not move the impeller by hand, although the bolt came off quite easy. Maybe the impeller was slipping when above 2.000 rpm.
 Do I risk Breaking the pump gears if I put the bike in gear and hold the brake while thightening the impeller bolt? Then I dont need to drain the new engine Oil [emoji56]
Chr
  • Copenhagen
Re: Impeller bolt
« Reply #4 on: May 07, 2018, 05:56:40 PM »
Remove the pump then tighten the fastener using the correct technique and torque value. Maybe the o-rings will be ok. The tightening torque differs between bolted assemblies and those fastened with a nut. According to Clymer: nut–19 Nm to 23 Nm, bolt–29Nm to 37 Nm.
This situation highlights the need to work mindfully and follow procedure.
Offline Enfield
Re: Impeller bolt
« Reply #5 on: May 08, 2018, 12:05:21 AM »
Thanks - you are right. Bike been sitting for 5 years + .... so a third oilchange in the first 500 km won’t harm[emoji41].
Regards
Chr
  • Copenhagen
