MOTOBRICK MARKETPLACE
NM ~ Not Mine - Just Compeled To Post It Up
FS : 1991 BMW K75RT - $2200 (not mine)
Topic: FS : 1991 BMW K75RT - $2200 (not mine) (Read 4533 times)
DavidATL
^ Proficient Motobricker
May 04, 2018, 06:58:55 AM »
No representation made. I have the seller's phone if the ad has expired and you want to contact them anyway. I exchanged texts with them regarding their home brew top case.
In Macon, GA. Posted 4/6. For sale as of yesterday.
(CL link at the bottom. More pics there)
"Selling my K75 because I'm getting into off road riding. Asking $2200 or best offer.
The good:
Runs great and Mechanically sound
All electronics, indicators, and gauges work
Keyed side bags with new hinges and keyed faring compartments
Homemade Top Case can be removed and restored to original if desired (no holes were drilled in the bike)
Front and rear tires have less than 500 miles
Within the past 3500 miles - Valves Adjusted, spark plugs replaced, water pump rebuilt, fuel filter replaced, fork oil and seals replaced, transmission and rear diff oil changed
Odyssey battery - maintained with Battery Tender
Regular oil and filter changes
Garage kept
Lots of storage between cases and under seat and faring compartments
Original ignition key also works for gas cap, side bags, seat lock, and faring compartments
Original owner's manual and tool kit included
Bar risers included (not installed)
Highway pegs
The bad:
Rough cosmetically
Cracked foot peg
Some paint chips and fading
Seems to have a lot of front brake lever travel. However, brakes work fine, no leaks in the system, and I've replaced the brake fluid.
Permanent cruise control - throttle grip does not return closed on its own
Mirror cracked
https://macon.craigslist.org/mcy/d/1991-bmw-k75rt/6554014107.html
Atlanta
K75RT '92 w/ 28k miles (former bikes: '82 FT500, 80's GL500 Silverwing, 550 Nighthawk and FINALLY an '88 K75S) https://georgiaroads.wordpress.com including my #GA4corners route
