Started the brick after putting in fuel. Only filled it about 3/4 full. smelled gas. back of engine wet and fuel dripping onto rear cyl exhaust header. looked and felt around but can not see or feel where it's coming from. I don't think it's the tank, and the hoses I can see looked dry. I searched and saw an old post with this "I fixed the fuel leak last night. The vacuum hose that runs to the bottom of the fuel regulator, the one covered by a wire spring, was split in half where it made a sharp bend going into the bottom of the regulator."
This may be my issue, but the pushing the spring back, the end I can see looks fine. any other thoughts on how to track down my issue. ? Do I need to drain the tank and remove to get to this?
