Author Topic: 87 K100 Steering head bearings  (Read 5660 times)
Offline 87K100RS Basket
« on: April 23, 2018, 05:51:25 PM »
Hello,
Curious if anyone could help me out with installation of steering head bearings. The clymer manual is a bit vague and I would like to make sure I get it right. What I need to know is whether the races that press into the frame sit flush with the frame or if they need to bottom out.
  • NH
  • 87 K100RS
Offline Chri5
  • Buy it - Break it - Rebuild it!
Re: 87 K100 Steering head bearings
« Reply #1 on: May 01, 2018, 01:04:33 PM »
the races (outer ring in the frame) should bottom out both sit a 1mm or so into the frame neck i have just done this on my K a note on my K at least the top race seat does not have a perfect edge so looks like its not quite seated but it is yours may be the same (check the lip/edge prior to install)  to ensure my where seated with out a press i used the old races (ontop of the new) 2 blocks of wood and a F-clamp to push them in after tap starting them worked a treat
  • United Kingdom
  • K100RS
Yamaha FZ6n-s2 electric conversion(Electric motor 240nm of instant torque)
Kawasaki Z750R
85 BMW K100RS
Buy - Break - Rebuild - Repeat!
Offline schrocketeer
« Reply #2 on: May 03, 2018, 11:13:06 AM »
How stiff is the steering in a K100 "normally"?
I just got my '85 K100 on the road this week, after a barn find. Highway stability is fine. Parking lot steering is stiff/scary, it is so hard.
For reference, I'm coming off of 50k+ miles on a Honda Shadow 600.
  • North Alabama
  • 1985 K100RT very original
Ken
« Reply #3 on: May 03, 2018, 11:20:48 AM »
33 year old grease in the bearings may have something to do with it.
Last winter I went into the steering head on a 92 K100 and the grease in the bearings had turned to glue and had to be heated to get it out of there.  The bearings would hardly move despite being perfect.
« Reply #4 on: May 03, 2018, 12:33:11 PM »
With the bike on the center stand have someone push the back down to get the front wheel off the ground. The wheel should turn slowly from center position to the left or right stop with just a nudge.  It it's stiff either the bearings are too tight or the grease is petrified.
Offline Enfield
« Reply #5 on: May 04, 2018, 02:39:07 AM »
Is that the Way to check - when assembling it? Or is there a torque setting for the main nut?
 I Got no play in mine but there is no resistance at all - also frels a little too loose on highway.
Regards
Chr
  • Copenhagen
  • K100 RS , K100, Royal Enfield Bullet
