Finally after 2 years of moaning and growning I got my water pump replaced.
I had first found out that I was getting some oil in the coolant reservoir and it was a layer of gray foam then I took to a "independent bow" mechanic and he said that it seem to be a bad head gasket and I would need to replace it, $$$$$$
I told him that I had to wait, and 2 yrs went by and I did a radiator flush and try to check for compression (not a mechanic) and could not figure out what the hell I was doing and gave up.
All I was told by other mechanics that I should have oil dripping out of the weep hole and none of that was happening, even when I poked the hole with a wire, so I thought that I would have to have the head gasket replaced.
I took the bike to a dealer and they checked and found out that it was the water pump bad, so I had it replaced and now it is fixed.
Many of you from this forum were correct, it was a water/oil pump and I just had my thrust in this "independent mech" Who came out right off telling me that it was the head gasket, and wanted to believe he was right but my conscious told me otherwise due to many of you experts. I learned another lesson even at this old age.
Thanks for all of you and I know this is the right place for information.
