Author Topic: Trouble starting, suspect fuel pump (video)  (Read 3058 times)
Offline frankenwing
  • Bolted • Brewed • Originals ☠ ☕ 🏍
« on: April 10, 2018, 06:53:34 PM »
Well today my K75 is refusing to start. It'll just barely start to fire but then give up. Couldn't figure out what the issue was. But then i started to notice a little fuel leakage out of the top of my gas tank. Odd. So i pull the cap assembly off, look around, try to start it and i find that the fuel pump is spraying fuel through the seams. I'm no expert but i'm pretty sure its not supposed to do that.
Bad fuel pump then?
[ONE-OFFS]
1976 GL1000 Bobber // 1987 K75
Re: Trouble starting, suspect fuel pump (video)
« Reply #1 on: April 10, 2018, 07:58:06 PM »
Could be something is blocking the flow as well.
Offline frankenwing
« Reply #2 on: April 10, 2018, 08:42:03 PM »
Yup Turns out there was something clogged in the fuel filter. Blew it out, hooked it all back up and it was running again. But I think because of the back up it hurt the fuel pump a little bit. It’s still spraying out of the seam, just not as much. Ordered a new pump and filter to be safe.
[ONE-OFFS]
Offline blakey
  • Learn to listen, listen to learn.
« Reply #3 on: April 10, 2018, 08:49:02 PM »
Can you tell us how old the pump was and was it an OEM unit?
blakey
K100RS 1986 RED!
North of Bris Vegas, Queensland, Oz.
Offline frankenwing
« Reply #4 on: April 10, 2018, 08:54:51 PM »
It is the oem pump, I believe the original but I don’t know for certain
[ONE-OFFS]
