Author Topic: Injector problems?  (Read 7819 times)
Offline Latvietis
Injector problems?
« on: April 08, 2018, 03:44:16 AM »
Hello brickers!
As i told some time ago I have 86’ K100 which had been sitting in the barn for 10 years. Had a bunch of problems because of sitting.
I ordered 4 new injectors: https://m.aliexpress.com/item/32823879186.html?trace=wwwdetail2mobilesitedetail&productId=32823879186&productSubject=32823879186&shortkey=AvInInuI&addresstype=600
Are they giving too much fuel? The bike does not star up! When i disconect fuel pump and try to start up it fires up for some time!
Hope you can help me wit your opinion and expertise!
Thank you!
PS. The old ones are rusted and 3 of them not even clicking!
  • Latvia
  • K100 86’
Offline Timbox
Re: Injector problems?
« Reply #1 on: April 08, 2018, 08:36:33 AM »
We need a little more information and how much trouble shooting you have done with the fuel system.  Have you taken a look in the fuel tank?  Did you fix the possible issues with the rubber vibration dampener and hoses in the fuel tank?
  • Tomah, Wisconsin
  • 87 K100 RS
1987 K100RS current project :)
In shed: 07 Bandit 1250, 86 FJ1200, 85 Madura 1200 and KLR650
Offline Latvietis
« Reply #2 on: April 08, 2018, 08:49:21 AM »
My fuel tank was a milk box for a while... when I bought it i was standing in the barn for more than 10 years without fuel! All original fuel injectors were wasted and i took fuel injectors from friend who has k100 too! After puting them on a bike it started 2 seconds later! Fuel pump make pressure, spark plugs are new. Ordered these injectors, but i thik they give too much fuel to the pistons!
  • Latvia
  • K100 86’
« Reply #3 on: April 08, 2018, 09:05:03 AM »
Based on the fact that your friend's OEM K100 injectors work, I would guess that your Chinese injectors are putting too much fuel into the cylinders.
If you have the time, can you put the Chinese injectors in your friend's bike?  If his bike won't start, you have proof that the injectors aren't correct.
Offline Latvietis
« Reply #4 on: April 08, 2018, 09:09:34 AM »
I thought that its the anount of fuel that it puts in the engine, because when i disconect the fuel pump it stars to fire up and i can hear explosions. While the system is under pressure no explosions..
  • Latvia
  • K100 86’
« Reply #5 on: April 08, 2018, 09:16:01 AM »
When you try to start with the pump disconnected you are cranking the engine with the fuel left over from the last time you tried to start.  As you crank, the engine is pumping the excess fuel out until what is left makes a correct mixture.  The engine fires once per cylinder and then quits because there is no more fuel.
« Reply #6 on: April 08, 2018, 09:18:16 AM »
These to me don't appear to be compatible injectors based on the published specs.
Yours:
Coil Resistance: 12 Ohms / High Impedance
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 47 lb/hr = 500 cc/min
BMW (Bosch 0 280 150 210):
Coil Resistance: 16 Ohms
Static Flow Rate @ 36PSI ( 250kPa ) w/Gas: 13 lbs/hr = 137 cc/min
According to the linked ad, you purchased high impedance injectors with way too high of a flow rate at a pressure that the K100 pump cannot attain.  Discard these and buy compatible injectors.  Then try again.
« Reply #7 on: April 08, 2018, 10:05:11 AM »
greetings latvietis...
1) run your vin... make sure you dont have a 85 as it is different than a 86...
2) post up photos of your moto so we can see whats you gotts...
3) you need to getts the right injectors... buying cheep will just cost you more down the road...
please do your doo dillergence... before searching for parts it is absolutely mandatory here at motobrick.com that you run your vin to verify your year and model... so many registrations and titles are simply wrong and that causes whack...
run your vin (last 7 digis only) in the serial number box here...
once you have a good part number you can run that part number to see moto fitment...
choose your product catalog series model market prod month here to getts good part number here...
click here for online etk crossreference... use the search by bmw part number box...
now latvietis... go getts the right stuff...
i used the search button and i have found several motobrockers like these injectors...
* inj1.png (242.84 kB . 527x347 - viewed 542 times)
* inj2.png (123.69 kB . 704x327 - viewed 478 times)
Offline Latvietis
« Reply #8 on: April 08, 2018, 01:47:20 PM »
When i saw a bike in an advertisment it looked like these first two photos. These were good photos because i could not see those big problems which were hidden.
Now i have gone through major points and cleaned stucked parts. Here are few photos for VIN:
Bike had only 27k km.
  • Latvia
  • K100 86’
Offline Latvietis
« Reply #9 on: April 08, 2018, 01:48:03 PM »
Thanks for advises! Will look for decent injectors!
  • Latvia
  • K100 86’
« Reply #10 on: April 08, 2018, 02:49:14 PM »
stick with it... you will getts it running and have a reliable heap to ride in the country with a new hoe on the back every weekend...
« Reply #11 on: April 08, 2018, 03:23:53 PM »
. . . and have a reliable heap to ride in the country with a new hoe on the back every weekend...
Hoe springs eternal in the human breast:
  • 1995 K75 89,000 miles
Offline bizzaro
  • co pilot
« Reply #12 on: April 08, 2018, 06:14:12 PM »
Did someone say "SPRING"??  :dunno The lost season in the northeast!  :musicboohoo:
Oh n Johnny, was just gonna mention that.........thanks man!
  • Vermont
See Ya in the Twisties,
 Bizz
Offline wally.fisher
« Reply #13 on: April 10, 2018, 10:20:06 AM »
Why not pack your old injectors off to tills.de  in Germany. They do an exchange for refurbished injectors. Good service as well.
Offline gph67
« Reply #14 on: April 10, 2018, 11:21:43 AM »
or send them to Dr. injector in Idaho, see what he can do with them.
  • seattle
  • K75
Offline Latvietis
« Reply #15 on: April 10, 2018, 11:36:20 AM »
Too far from me :(
  • Latvia
  • K100 86’
