Author Topic: Shit lever free play  (Read 7246 times)
Offline BearTrap
« on: April 05, 2018, 04:39:43 PM »
I’m just throwing this out there since I cannot find a definitive answer to the shift lever free play for a K75. I have been experiencing rough shifting between 1st to 2nd and 4th to 5th.
In neutral the lever has a .75” travel up and down before meeting resistance. Shifting into 1st is a full 1.5” before completely engaging. 2nd, 3rd, 4th and 5th all have a full 1” travel before engaging.
Does this sound normal? This is my first BMW so I don’t have anything to compare it with.
1990 K75 Standard
53K on the clock.
Recent complete spline lube and clutch inspection.
Clutch cable properly adjusted.
Fresh 80wt gear oil.
  • Rancho Mirage, CA
  • 1990 K75 low seat
Offline blackie1
  • christchurch nz
Re: Shit lever free play
« Reply #1 on: April 05, 2018, 04:49:19 PM »
hi
I am certainly no mechanic but if you enter "grub screw" in the search box above , some of those threads may help you out.
  • 1991 K75RT naked 67,000kms
« Reply #2 on: April 05, 2018, 04:50:13 PM »
Read this. Does it seem like what you're experiencing? It's understandable that you've characterized it as you have in this thread's title. :giggles
« Reply #3 on: April 05, 2018, 05:01:17 PM »
Start at 1:05. Have some coffee. His soothing voice can lull you to sleep.
Offline BearTrap
« Reply #4 on: April 05, 2018, 06:18:59 PM »
Shit lever is right  :eek:  Thanks for all the feedback. Looks like I'm gonna have to pull the tranny to get that grub screw tightened up.
Cheers
  • Rancho Mirage, CA
  • 1990 K75 low seat
Offline bizzaro
  • co pilot
« Reply #5 on: April 06, 2018, 09:25:49 AM »
Damn! My bike doesn't have a "SHIT" lever.  , I knew for their time these bikes were advanced. Fuel injection. ABS. But I have to pull over n stop............unless I am going well over the posted limit and some fuckin idiot at the intersection pulls out in front o me.
  • Vermont
See Ya in the Twisties,
 Bizz
Offline BearTrap
« Reply #6 on: April 06, 2018, 11:07:57 AM »
After watching the video, I have determined that shift lever does not have any play. She is tight! :clap: No need to pull the tranny. I guess these bikes have a long throw to engage the gears. Anyhow, I still love my K.
I will soon be posting a review on my experience on my new Shinko tyres.
Cheers! :2thumbup:
  • Rancho Mirage, CA
  • 1990 K75 low seat
Offline bizzaro
  • co pilot
« Reply #7 on: April 06, 2018, 11:33:37 AM »
Also, try more "shit" lever and less clutch.  You only have to put a little pressure on the clutch control rod to get disengagement. And it should slip into gear like butter!
  • Vermont
 Bizz
Offline BearTrap
« Reply #8 on: April 06, 2018, 11:34:43 AM »
I'll give that a shot.
  • Rancho Mirage, CA
  • 1990 K75 low seat
« Reply #9 on: April 06, 2018, 01:18:32 PM »
+1  A short, quick snatch on the clutch when shifting almost pulls the transmission into the next gear.  Barely a half inch of pull is all it needs.
« Reply #10 on: April 06, 2018, 02:45:38 PM »
When riding two up with my wife I often don't pull the clutch at all, just very slightly roll of the gas and shift up .. that way there is a less of a chance of the missus headbutting me from behind when I shift!
« Reply #11 on: April 06, 2018, 02:53:36 PM »
shifting without clutching the motobrick can reduce clutch life by as much as 50%...
« Reply #12 on: April 06, 2018, 09:13:10 PM »
I am sure you are right but searching on the internet I found a huge variance in opinion. I do see videos saying it is bad for the dogs and others saying it is fine but since the clutch is never disengaged I do not see how it can hurt the clutch.  Either way the risk of hurting the dogs is enough to make me stop doing, not that I did it a lot in the first place.  Shame, a well executed clutchless upshift is very satisfying
