Author Topic: Oil/water pump seals?  (Read 4303 times)
Offline Gr-Racing
« on: April 03, 2018, 04:39:09 PM »
Hey guys my k75 is pumping white smoke like a lot and im going to do a water/oil pump rebuild
I saw different info on the seals i need so maybe you can give me some clarity
Can i just buy the kit from motobin and thats all i need?
Should i also change the impeller?
Of do i need to buy this full list of OEM parts?
  • GA
  • K75
Re: Oil/water pump seals?
« Reply #1 on: April 03, 2018, 04:56:41 PM »
do you have oil in your coolant... or coolant in your oil...
Offline thecableguy
« Reply #2 on: April 03, 2018, 05:00:29 PM »
Are you sure that's what it needs?  Is there a oil or water leak coming from the weep hole on the bottom of the pump?
White smoke usually tells me we either have a new pope or you have a bad head gasket...
Also... what jo said...
Jim
  • Madison, WI USA
  • 86 K100RT - Brünhild
...to make a long story short, use duct tape.
Offline Gr-Racing
« Reply #3 on: April 03, 2018, 05:14:13 PM »
Small amounts of oil in coolant
  • GA
  • K75
« Reply #4 on: April 03, 2018, 05:38:37 PM »
Should i also change the impeller? Of do i need to buy this full list of OEM parts?
You'll need all those parts plus a stamped impeller if your pump has a cast impeller. Put your bike's year in your profile and whether it's a C, T, S, or RT. Changes occur in parts throughout the years. Is oil coming in drips from the pump's weep hole?
As thecableguy has observed, white smoke indicates that the head gasket might be leaking, especially if it keeps occurring after the engine is warmed up. You might be able to observe bubbles in the coolant reservoir. Those would be caused by a head gasket leak. You should determine this first before laying out cash for pump parts.
« Reply #5 on: April 03, 2018, 06:15:28 PM »
