Author Topic: K100 upside down front fork project. NEED HELP.  (Read 10108 times)
Offline Blackened6969
« on: March 23, 2018, 09:41:15 AM »
Any pointers in fitting upside down forks to a k100,which you would recommend,had suzuki hayabusa in mind,the complete front end wheel brakes etc.
I'm aware that I will need to change bearings and stem.wanted to know about the off set in the different triples and whether the new front end would clear the petrol tank.
  • Uk
  • K100 ducati 996
Offline MaraudeRS
Re: K100 upside down front fork project. NEED HELP.
« Reply #1 on: March 23, 2018, 05:00:16 PM »
Hi Blackened. I’m doing a front end swap on my K100RS to a 06/07 Gsxr600/750 front end. As recommended by Mike Flores, I went with a new triple clamp setup from Cognito Moto. It came with the stem I need and I was able to get the tapered bearings from them too. Here’s what it looks like
  • Monterey, CA
  • 1992 K100RS
« Reply #2 on: March 24, 2018, 02:43:10 AM »
Thanks MaraudeRS.
I'll go to there website,best advice i've received upto now.cheers.
  • Uk
  • K100 ducati 996
Offline CG_3D
« Reply #3 on: March 24, 2018, 07:50:33 PM »
I'm doing a GSXR 1000 (05'-06) fork. Also got the Cognito stem, but making my own upper and lower clamps.  :2thumbup:
  • Kenosha, WI
  • k100
Offline Mike Flores
« Reply #4 on: March 26, 2018, 05:45:51 PM »
I'm using the Cognito stem and triple tree set. My forks are from a 2015 GSXR 1000.
  • Los Angeles, CA
  • 1987 K100
Offline MaraudeRS
« Reply #5 on: April 03, 2018, 12:38:34 AM »
Thanks MaraudeRS.
You’re welcome. Let us know how your swap goes.
  • Monterey, CA
  • 1992 K100RS
Offline waynerp
« Reply #6 on: May 02, 2018, 01:49:48 PM »
Hi Mauraders
So was this a simple bolt on job? All the bearings and everything needed to fit the forks correctly? Im thinking of using GSXR forks so am looking at best options to fit.
Many Thanks
  • Kent
  • K100RS 1986
Tags: usd
