Author Topic: LED Replacement Board for Gear Indicator in OEM Cluster  (Read 33742 times)
« on: March 09, 2018, 07:14:42 PM »
I'm finishing up working on a new electronic board and posting my progress here.
The age of our bikes means that certain electronic components, like the LCD displays in the instrument cluster, are reaching their end of life.  The gear indicator is one of those components that slowly dies by having the liquid crystal fluid leak between the glass.  The LCD used by BMW is special and not available from any electronic parts supplier in the world.  But this is where my board comes in.  The board I've designed is a drop-in replacement for the LCD gear display.  It will fit on the GPI board inside the cluster and will replace a failed LCD display.
Below are pictures of my working prototype installed on a GPI board and a picture of the underside of the board.
The board is held in with 2-56 screws in the original holes.  The board shows as being a little oversize but I'll correct that in the next batch of printed circuit cards.  The displays I chose are Red in colour but I can choose other colours as well.   It is necessary to make one small modification to the GPI board to get this to work.  The modification consists of cutting through one of the PCB traces on the board and soldering a small jumper wire across two pins on an IC.  The modifications are not difficult.  You can see the modification in the photo below, right at the top of the GPI card.  There is a cut trace near the number "11" on the board, and the yellow jumper wire:
Others have added a LED display to the OEM GPI board but needed to heavily modify the board in the process.  Not here.  There are small pins that contact the original pads on the GPI board, as you can see in the photo above.
I have one last task in this project and that is to design and 3D print a part to accept the two mounting screws.  Once I have that complete, I'll start to offer this for sale.
6th Gear Modification
Slightly related to this, it is possible to modify the BMW GPI board to indicate 6th gear.  I helped a guy with this modification as he was installing a K100 cluster on a three-wheeled vehicle.
The modification is to add a small jumper as illustrated in the photo below.  Once done, the GPI board will indicate gears 1 through 6 and neutral.
Re: LED Replacement Board for Gear Indicator in OEM Cluster
« Reply #1 on: March 10, 2018, 12:50:02 AM »
 :clap: :clap: As always an excellent piece of engineering.  :2thumbup: :2thumbup:
« Reply #2 on: March 11, 2018, 10:02:52 AM »
That's so awesome. My K only has five gears, looking forward to having 6 after I install this mod.
Seriously, thank you for your service!
Offline KRider
« Reply #3 on: March 18, 2018, 11:19:35 AM »
Looks real nice! I know some use that board to get off the gear neutral indicator with a universal digital speedo, tacho instead to use relays. But should it be possible to use that board to to get a gear indicator to work in a universal speedo with built in gear indicator?
« Reply #4 on: March 18, 2018, 11:39:46 AM »
Hi,
No, it's not possible to get this board to drive the typical integrated gear indicator in an aftermarket gauge. The only functions you can "export" from this board is neutral detect and start enable.
The aftermarket gauges that I have seen offered on Ebay and through custom shops provides 6 individual wires to drive the internal display, each wire dedicated to a gear number.  The gauge expects the wire to be grounded to indicate the selected gear.
This OEM board has a BCD to 7-segment decoder chip (a CD4543) that will drive each outputs on the chip in combinations that represents a decimal digit between 0 and 7 on the LCD display.  See my OEM schematics page for the details. There is no function on that chip that is compatible with the gauge.
Offline KRider
« Reply #5 on: March 19, 2018, 06:58:25 AM »
 Ah, i see should be to good to be true:) Thanks for your answer.
 I have send you a PM about the TPGI board you have have designed.
Offline Kiffchr
« Reply #6 on: November 08, 2020, 11:44:33 PM »
Is this board still available and how much?
  • Coeurdalene, ID
  • 1986 K75C
Offline moto1337
« Reply #7 on: May 26, 2022, 10:37:56 PM »
Bump, just in case anyone has been in touch with OP
  • Concord, MA
  • 1986 K100
« Reply #8 on: May 27, 2022, 01:02:45 AM »
I really have to re-vamp this thread.  I have some of these boards available.  I made a small production run of about 10 boards if anyone is interested.
Offline moto1337
« Reply #9 on: May 27, 2022, 11:27:16 AM »
Hi Robert, I'm very interested -- please let me know how I can work with you to get ahold of one of these.
  • Concord, MA
  • 1986 K100
« Reply #10 on: May 27, 2022, 11:47:04 AM »
Sign me up for one, too.  My RS gear indicator has the black death beginning to creep across the screen.
« Reply #11 on: May 27, 2022, 11:53:29 AM »
Please report the pics when you can. I'd be interested in one too.
Offline Atabeach
« Reply #12 on: May 06, 2024, 10:16:12 PM »
…I’m assuming this is- or never was available?
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Online Laitch
« Reply #13 on: May 06, 2024, 10:37:14 PM »
Send a PM to rbm and find out.
« Reply #14 on: May 07, 2024, 05:09:59 PM »
I still have some units available.  They look like this installed on the gear indicator board:
And close up:
Offline moto1337
« Reply #15 on: May 08, 2024, 11:37:07 AM »
As a testimonial for these LEDs, the one on my '86 K100 works great. Minor soldering required.
  • Concord, MA
  • 1986 K100
