Author Topic: small breather tube  (Read 3904 times)
Offline richarddacat
small breather tube
« on: March 06, 2018, 07:56:04 PM »
During a TBS on my K75 I notice my fan never came on as it heated up. So I took the radiator off and sure enough the fan is shot, barely turns, not free and wouldn't run with a battery hooked up.
Anyway, I saw this small breather, I'm guessing but it had a rotten rubber cap over it. Thought this was strange, IF it isn't a vent what is its use?
Re: small breather tube
« Reply #1 on: March 06, 2018, 08:22:21 PM »
that vent should be capped off, BMW was experimenting with some emissions plumbing that didn't work very well so that cap is the accepted solution.
« Reply #2 on: March 06, 2018, 08:26:53 PM »
Thanks.
« Reply #3 on: March 07, 2018, 01:42:07 AM »
While you are there it would be a good idea to clean the fuel sensor connector with DeoxIT. I also smear heavy silicone grease around the plug to try and keep the road crap and water out.
