Author Topic: Front Brake Hose Replacement  (Read 7145 times)
Offline lilau3
« on: March 02, 2018, 08:23:16 PM »
Hi, Does anyone know of an off the shelf solution for a brake hose that goes from the front lever directly to the caliper?
Bike is a K100 LT and I have just naked-ified it and removed all the ABS components.
Cheers
  • Australia - Melbourne
  • 1988 BMW K100 LT, Vespa GTS300
Re: Front Brake Hose Replacement
« Reply #1 on: March 02, 2018, 08:41:12 PM »
I just get mine made up by a local automotive brake shop. They can do them on the spot in black covered stainless braid. I just show him what I want and he makes it up on the spot. And it's a lot cheaper than going to motorcycle shops or specialists and you don't have to wait.
« Reply #2 on: March 02, 2018, 08:44:36 PM »
Australia's a big place it would help if you posted your town and state.
Offline lilau3
« Reply #3 on: March 03, 2018, 12:46:09 AM »
I’m based in Melbourne but happy to order online internationally if required.
« Reply #4 on: March 03, 2018, 02:01:27 AM »
No need to order internationally, just ring your local brake shops until you find one that will make your line. Hydraulic shops would also be a source of lines. My across the road neighbor has a mobile hose making business and he can do them. You just need to look around.
Offline beemerphile
« Reply #5 on: March 03, 2018, 07:59:08 AM »
It is amazing to me how little the length of a custom hose has to be wrong before it either won't work or looks terrible.  Instead of trying to measure the length with a tape, get a length of plastic tubing about the same diameter and thread it into position.  Then cut it at each end where it crosses the centerline of the banjo fittings.  Lay it out and measure it to get the hose length you need from banjo to banjo.
  • Danielsville, GA 30633
  • 1993 K1100RS "Lenora"
Lee
Offline lilau3
« Reply #6 on: March 07, 2018, 05:08:10 PM »
Thanks for the advice @Martin Had a hose made up by Ace Brake and Clutch in Kensington (VIC). Can recommend their service.
« Reply #7 on: March 09, 2018, 12:40:50 PM »
Lilau for interests sake how much was the hose and did they do it on the spot?
Offline lilau3
« Reply #8 on: March 09, 2018, 06:35:44 PM »
It cost $85 and they took a day to do it.
« Reply #9 on: March 10, 2018, 12:29:02 AM »
 :2thumbup:
« Reply #10 on: March 11, 2018, 10:17:44 AM »
What about the other caliper? I mean, the one on the other side of the wheel?
Offline lilau3
« Reply #11 on: March 11, 2018, 03:42:29 PM »
There is a piece of rigid metal hose joining the two calipers.
My LT didn’t seem to have the hose splitter running through the headset like I’ve seen on other bikes. Not sure it it’s an LT specific thing?
« Reply #12 on: March 11, 2018, 05:51:20 PM »
Someone will correct me, but I thought that was a K75 feature. I recall once looking into converting my K100 to it to get rid of the splitter.
Offline lilau3
« Reply #13 on: March 11, 2018, 06:35:25 PM »
Not sure @billday, all I know is that pretty much everything else was stock on the bike so I would be very surprised if it wasn't the original component.
« Reply #14 on: March 12, 2018, 10:19:59 PM »
In the MAXBMW parts fiche, that assembly is shown as a stock option (Diagram #34_0657) on the 2V K100LT '86–'91.
  • 1995 K75 89,000 miles
Offline lilau3
« Reply #15 on: March 13, 2018, 02:41:28 AM »
It certainly makes bleeding the brakes a lot easier.
