Author Topic: "Revive" (1985 K100 Street Scrambler Build, not a Cafe Racer)  (Read 444150 times)
Offline DJEwen
Re: Triple S
« Reply #225 on: July 10, 2018, 03:34:01 PM »
This is my attempt at rectifying the damage caused to the RHS seam where the tank leaked. Fingers crossed it comes out alright.
  • Scotland
Re: Triple S
« Reply #226 on: July 10, 2018, 04:14:15 PM »
Is this another way of saying that the coating of the tank's interior didn't work?
Offline DJEwen
Re: Triple S
« Reply #227 on: July 10, 2018, 04:26:07 PM »
No, no. The coating on the tank worked perfectly.
The tank didn’t leak before it went for paint, didn’t leak once immediately filled afterwards, or four hours later. It wasn’t until the following day that I realised fuel had migrated through overnight and had removed the paint in the RHS step. That was what prompted the POR15 repair, which worked perfectly, I’m only now rectifying the paint damage.
  • Scotland
Offline DJEwen
Re: Triple S
« Reply #228 on: July 10, 2018, 04:26:47 PM »
I forgot to share this. I tried on a spare cafe seat I have.
Will be selling this shortly.
  • Scotland
Re: Triple S
« Reply #229 on: July 10, 2018, 04:36:47 PM »
I'm glad to hear that the product worked well. Tank leaks can strike any of us, regardless of political affiliation or handedness.
Offline DJEwen
Re: Triple S
« Reply #230 on: July 10, 2018, 04:42:44 PM »
Thanks, Laitch. I wish I had just done it as a matter of course in the first place. Should I ever build another, this will form part of the process regardless of tank condition.
Lessons learned.
  • Scotland
Offline DJEwen
Re: Triple S
« Reply #231 on: July 11, 2018, 03:38:12 PM »
The touch-up came out alright;
Got a shock at how dirty the oil seems already. I’m 602 miles in now. Like any internal combustion engine I suspect this is normal?
  • Scotland
Offline Skunky
Re: Triple S
« Reply #232 on: July 12, 2018, 12:18:02 PM »
That's what you get for changing the sight glass. The rest of us can blame fogged up glass for the dirty looking oil.  :hehehe. Anyway that looks reasonably clean to me. When its black its dirty.
  • Derby GB
  • BMW K100lt
90 K100lt
Triumph Thruxton 900
Honda CB400F
Offline alabrew
Re: Triple S
« Reply #233 on: July 12, 2018, 12:57:03 PM »
And you can't get all the dirty oil out so it mixes with the new.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
Offline DJEwen
Re: Triple S
« Reply #234 on: July 12, 2018, 03:36:21 PM »
No half jobs here  :neener:
Sweet  :2thumbup:
Plays havoc with my OCD  :giggles
  • Scotland
Offline DJEwen
Re: Triple S
« Reply #235 on: July 12, 2018, 03:44:02 PM »
The new turn signals arrived so I set to work:
OLD
NEW
The eagle eyed of you will have noticed my tail light is smashed :( Design flaw on my part. Strangely I hadn’t considered it being ravaged by stones off the back tyre... anyway, new one is on order and I’ve marked out a deflection plate in some 1mm steel which I’ll spray black and install with the new unit, should be unnoticeable. Luckily the actual LEDs are red and not just a red lense so I’m safe for the moment.
Really happy with the turn signals.
  • Scotland
Offline Skunky
Re: Triple S
« Reply #236 on: July 12, 2018, 04:14:53 PM »
Sharp, bright and looking good.  :clap:. Will you get your new back light before the show this weekend.
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline DJEwen
Re: Triple S
« Reply #237 on: July 12, 2018, 04:56:46 PM »
Thanks to you, Skunky!!
Unfortunately not, it won’t arrive until Tue/Wed. Not going to win any prizes for a smashed tail light but there’s always next time.
  • Scotland
Offline DJEwen
Re: Triple S
« Reply #238 on: July 13, 2018, 04:28:36 PM »
I didn’t ride her for three days and now she’s angry.
I went out to ride her to the gas station for a top-up ahead of the run to the event tomorrow. No start, no start, no start.
Pulled the tank 4 pin, cleaned, dried, no start. Pulled the FICU plug, cleaned, dried, no start. Tank off, 4 pin, no start, ICU clean, dry, no start.  :dunno2: Pulled the FICU plug again, cleaned, dried and she started on full choke but when given any throttle, died. This went on for about 5 minutes until she was a little warmer but then would not stay running unless the throttle was open even on full choke.
I let her die, threw on my helmet, jumped on started and rode off. Once the bike was up to temp I closed the choke. First set of lights she died but then restarted off choke and idled fine. This was a hit or miss for the next 10 junctions/lights, the ride between each set of lights was a mixture of no issue or a miss firing feeling as if running out of fuel, very spluttey, feeling starved.
Got fuel but then half a mile from home she died at the side of the road. I restarted her and no complaints, rode home, pulled up to the garage and she died.
What do you guys think? Fuel Pump, injectors, FPR, electrical. Potentially the pump is too far down in the holder as Laitch once experienced. FYI the filter is new and the bike was running perfectly when parked-up on Monday.
It’s worth noting also, I changed the fuel sender on Monday when I painted the tank seam... could this be a problematic 4 pin?
I have a video here, the bike is at temp and maintaining an idle now albeit erratic:
  • Scotland
Offline DJEwen
Re: Triple S
« Reply #239 on: July 13, 2018, 05:53:08 PM »
Reading this post back to myself I realised I was forgetting Law #3, trouble shooting: Look where you last worked. Went back in the garage, drained the tank, pulled the pump, disconnected the new old sender, removed the new old sender, reinstalled the old old sender, boxed everything back up, started, no complaints went for a 3 mile run, borderline perfect.
Cinderella shall go to the ball.
  • Scotland
Re: Triple S
« Reply #240 on: July 13, 2018, 06:30:47 PM »
. . ;. disconnected the new old sender, removed the new old sender, reinstalled the old old sender . . .Cinderella shall go to the ball.
Why was there a new old sender in there anyway—treatment by part substitution via the shotgun approach? Don't run over any glass slippers.
Offline alabrew
Re: Triple S
« Reply #241 on: July 13, 2018, 06:35:57 PM »
So it probably was the 4 pin into the tank? Can't figure out why the fuel sender (fuel level sensor?) would cause poor idle?
Also:
2005 K1200LT
1979 R65
Re: Triple S
« Reply #242 on: July 13, 2018, 06:55:14 PM »
This seems to be the year for dodgy fuel level senders.  I'm read about half a dozen or so different threads where internals on the senders suddenly go intermittent.  Every year it's something -- dodgy HES, dodgy ECUs, gummed up injectors.  It's inevitable.
Re: Triple S
« Reply #243 on: July 13, 2018, 08:00:29 PM »
Clusters of sprag problems, leaking tanks, etc.  The srevivce issue of the year.  How does that work???
Offline DJEwen
Re: Triple S
« Reply #244 on: July 14, 2018, 02:47:33 PM »
Page 1, post #22, the original sender plug connection was fire damaged. I dressed it up with some heat shrink and electrical tape but that half assed approach was not the direction this build went in and I’d have been embarrassed to ever sell it in that state so purchased a new used one from my local motor works. I did notice the plug connection wasn’t great, the fire damaged one was nice and tight whereas the replacement one was more like throwing a hotdog down a rabbit hole.
Potentially the 4 pin connection itself yes or the internals degrading as RBM has mentioned, I’ll never know. Anyway, out with the old and in with the old... wait, what...
Inevitable concerns me. This is my only bike, think it’s time for another so I can walk away when the K is crying for something else.
  • Scotland
Re: Triple S
« Reply #245 on: July 14, 2018, 02:59:30 PM »
Page 1, post #22,
Ewen 1:22
As difficult that is to envision as a tattoo, somebody might be moved to do it. :giggles
Offline DJEwen
Re: Triple S
« Reply #246 on: July 14, 2018, 03:13:30 PM »
Ewen 1:22
Laitch, I’ll have that tattooed on my next “cheap week” holiday!
  • Scotland
Offline DJEwen
Re: Triple S
« Reply #247 on: July 14, 2018, 03:40:13 PM »
We rode up to the Tomintoul Motorcycle gathering today, I decided not to enter the bike in the comp as the prize giving wasn’t until much later on and we weren’t overnighting due to commitments tomorrow, plus, there were some real heavy duty builds there.
I instead sampled the local delicacys, chased some Haggis and tossed the cabre.
Anyways, I was two up for the journey there and back. The bike wasn’t running fantastic, felt a little lumpy, throttle wasn’t greatly responsive, a little slow and spluttery. I have yet to sync the throttle bodies, I’ll do that this week, valve clearances are all fine also- what are the causes? Vac leak? I did install the plenum mounts with gasket sealer as well as the o rings and the rubbers where all fresh so don’t expect a leak around there.
At mile 112 she started to run out of fuel, luckily the road consisted of twisties to the next gas station, she died as I was rolling in at 115 Miles. So, 115 Miles to a tank with pillion averaging 50/55mph. Does that sound like good range carrying pillion?
  • Scotland
Re: Triple S
« Reply #248 on: July 14, 2018, 05:44:17 PM »
You're running 115 miles on 3.3 Imperial gallons, which gives you 34.8 miles/imperial gallon.  In metric, that's 6.75 l/100km.  That's not too good.  You should be more in the region of 5.3 - 5.5 l/100km which is 53.2 miles/imperial gallon.
Here's a link to my Fuelly results for my K75.  A K100 should be close.
With the lumpy response and the rather poor showing on fuel economy, there might be something up with the water temperature sensor.  It might also be the "Z" tube leaking between the crankcase and air plenum.  Try the test using propane gas around the TBs while the bike is running.  Lots of threads about how to conduct that test.
I highly doubt that TB sync problems gives you the symptoms you're seeing but it certainly will help towards fuel economy and better running to do that procedure.
Funny Funny x 1 View List
Re: Triple S
« Reply #249 on: July 14, 2018, 07:42:56 PM »
I wouldn't expect as high a result as Robert is quoting if you're riding two-up in hilly conditions, but you should be somewhere in the forties. The two of you are svelte riders.   :yes 34.8 is too low. Part of it might be down to gear choice. Try riding only downhill. That should help.
Like Like x 1 View List
