Author Topic: alternate parts fuel pump relay  (Read 6793 times)
« on: February 18, 2018, 05:43:03 AM »
2000 model bmw 318i car
Various other bmw cars have a light green five pin relay
The pins and picture on the case are oriented the same as the bricks fuel relay. A resistor is shown in parallel with the coil. unfortunately i threw away the bad relay from the bike but the car replacement relay's resistor has the colour code green, blue, black, black, brown which i think means 560 OHM's. This bike is new to me but ive done 2,000km using this alternate relay without issue. Hopefully someone has a faulty original to compare resistors.
Re: alternate parts fuel pump relay
« Reply #1 on: February 18, 2018, 06:08:11 AM »
You should be able to read the complete part number or the last five digits of it (depends on the manufacturer)
Part number is: 61 36 8 373 700.......if the relay is identical.
« Reply #2 on: February 19, 2018, 12:24:50 AM »
6136-8 373 700 is the Part No. from BMW 318i, Siemens relay, colour; light green.
1459 5743 is the Part No. from '86 k100 RT BMW relay,    colour; black.
Bit confused now, i think next time the tank comes off ill put an original back in and keep the green one in the boot as a spare.
« Reply #3 on: February 19, 2018, 05:12:32 AM »
You can use both......the black one is a earlier model made by Wehrle.
The green one is what you would get if you order one from BMW today, but made by Tyco.
« Reply #4 on: February 19, 2018, 11:07:13 PM »
Bonus, good to know. (also i popped the cap on an original to find that the resistance is also 560 OHM's)
Offline TommyT
  • New Brick Owner
« Reply #5 on: July 24, 2019, 07:14:00 AM »
So in conclusion the 318i relay is the same?
  • Olive NY
« Reply #6 on: July 24, 2019, 07:57:56 AM »
Yep, lots of other model BMW cars have the same relay,  it's light green in colour. I doubt all 318i models of all years would have it, but if it's light green with five pins, check the part number,  it will probably be the same. I've had it in my bike a few years now without problems.
One of them had about five of these relays,  a turbo model,  from memory.
If your bricks relay is the old style (square when looking from the top,  not rectangular) it will work.
Offline TommyT
  • New Brick Owner
« Reply #7 on: July 24, 2019, 08:24:41 AM »
Thanks
  • Olive NY
Offline volador
  • NEEDS MORE CHROME
« Reply #8 on: October 06, 2020, 03:20:18 AM »
Amazon Lime FI Relay
FI relay 5blade 61368373700
Load shed 4blade 61311459677   Relay, K75 - K1100LT; R80R - R100MYS. This relay is assigned to multiple uses.
Including: fan, starting load shed, horn, Motronic, and fuel pump on selective models.
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
