Author Topic: Rebuild questions, probably first of many  (Read 4483 times)
Offline woodgeek
« on: February 10, 2018, 11:53:33 PM »
So, I’m tearing off everything relevant to the intake above the engine block to begin a rebuild.
First some thoughts. In thirty years of riding, this is my first fuel injected motorcycle, so I’m a little nervous. Working on this engine is like working on a car—which it sort of is since BMW sourced it from a car.
Questions: if the FPR is a Bosch unit, it’s safe to assume it’s been replaced at some point in its lifetime. I’m hoping it’s good as I can’t test it. I’d like to relocate the FPR to a location above the coils. Has this been by anyone before?
I was researching the prices on radiator hoses—crazy $$$?! If they’re not cracked, is there any sense in replacing them? Even though the bike hasn’t been titled in 18 years, the coolant is still clean.
There’s 50k on the bike so out of curiosity I pulled the starter to clean it. It was very clean inside. I’m beginning to think this was a well maintained BMW until it was mothballed.
  • Henderson, NV
  • 1985 K100RT
Re: Rebuild questions, probably first of many
« Reply #1 on: February 11, 2018, 12:02:04 AM »
You were?
  • 1995 K75 89,000 miles
Offline woodgeek
« Reply #2 on: February 11, 2018, 12:08:11 AM »
You were?
Thanks Laitch.  I knew I should have checked the alternate parts page. Rockauto is becoming my new best friend.[emoji4]
  • Henderson, NV
  • 1985 K100RT
« Reply #3 on: February 11, 2018, 10:01:17 AM »
Are you sure you need to replace your hoses?  I now have four 90's vintage bricks crammed in the garage, and can confidently say that the parts least likely to show the age of the bike are the coolant hoses.
Even if you have a damaged hose that demands replacement, I would not hesitate to take a chance on a used part from the interweb.
Offline woodgeek
« Reply #4 on: February 11, 2018, 10:51:45 AM »
That was certainly part of my question. I don’t want to replace them if it’s unnecessary. I pulled three of them off to make room to work on the intake. They don’t feel brittle and they don’t show any cracks. I’ll probably use some 311 UV protectant on them to clean them up and call it good.
  • Henderson, NV
  • 1985 K100RT
Offline F14CRAZY
« Reply #5 on: February 11, 2018, 11:02:43 AM »
The hoses on my K75 are original according to the dates stamped on them. They still look and feel fine. I wouldn't hesitate to run to U-Tall with them
  • Grand Rapids, MI
  • '87 K75C
« Reply #6 on: February 11, 2018, 11:58:03 AM »
Rubber parts can be rejuvenated with essential oil of wintergreen.  This combined with IPA, soak the part will restore the flexibility of the material.
http://v4musclebike.com/forums/showthread.php?t=13477
Wintergreen oil is available at any health food boutique.
« Reply #7 on: February 11, 2018, 02:21:03 PM »
IMO, unless the parts have hardened up to the point where they are getting brittle I would avoid using any applications to soften them up.  These compounds have solvents in them that will eventually break down and remove the plasticizers that were compounded into the part when it was manufactured.  This will significantly reduce the life expectancy of good parts.
