Author Topic: Hi from Denmark  (Read 19256 times)
Offline Enfield
Hi from Denmark
« on: January 25, 2018, 04:13:56 PM »
Hi. Been asking lots of quedtions here - thanks for helping me out!! Thought that I should post some pictures of my project. It started out with worn rusty K... now almost done... just waiting for spring!!
  • Copenhagen
  • K100 RS , K100, Royal Enfield Bullet
Offline rbroen07
Re: Hi from Denmark
« Reply #1 on: February 01, 2018, 11:59:48 AM »
Hej Enfield
Super flot byggget! Jeg er selv igang :)
I just have a few questions, that I hope could help me with my build.
What rear spring are you using?
What did you use to paint the engine, and how did you clean/prep it?
What did you use to paint the frame, and how did you clean/prep it?
[/size]What did you use to paint the wheels, and how did you clean/prep them?
[/size]
[/size]What did you use to paint the tank, and how did you clean/prep it?
[/size]
Did you change the tires yourself or did you have help from a professional?
Venlig hilsen
Rasmus
  • Denmark, Copenhagen
  • BMW K100 '83
Offline mikkel neess
Re: Hi from Denmark
« Reply #2 on: February 01, 2018, 01:42:30 PM »
Super nice - Lidt sjovt at finde 2 mere i gang med næsten samme projekt.
Keep up the nice Work....
I will try and upload a bit from my stuff later.
 :clap: :clap:
  • Denmark
  • R65 1981, K100 RS 1983, Previous 2008 CBR600, Hornet 600, 1995 CBR
Offline Enfield
Re: Hi from Denmark
« Reply #3 on: February 01, 2018, 02:41:12 PM »
Hyggeligt med flere fra Dk - går og skruer i Charlottenlund.
 Hi I had frame and engineparts powder costed - sandblasted first! No problem with the frame - but ve sure to find someone who have blasted aluminium before!!! They were a bit hard on my engine parts - they do look ok - but could have been better. For cleaning i used something called Maxi 3 and very very warm water - tales almost everything off.
 A lot of the small parts I blasted with Natrium Bicarbonate - 25 Kgs for next to nothing og you buy it somewhere ( DLG in Denmark) where they sell supplies for livestock.
 Regards
Christian
  • Copenhagen
Offline Enfield
Re: Hi from Denmark
« Reply #4 on: February 01, 2018, 02:42:34 PM »
And rear spring is from a K1100
  • Copenhagen
Re: Hi from Denmark
« Reply #5 on: February 01, 2018, 02:45:05 PM »
What is the difference in the spring from the 1100 to an early K-model (83)
  • Denmark
Offline Enfield
Re: Hi from Denmark
« Reply #6 on: February 01, 2018, 02:45:56 PM »
A bit longer - not sure how much.
  • Copenhagen
Offline Enfield
Re: Hi from Denmark
« Reply #7 on: February 01, 2018, 02:48:58 PM »
I needed the extra height as I didn’t want the end of the frame to go upwards.
 With normal spring there would be Way to little distance to the tyre!
  • Copenhagen
Offline DJEwen
Re: Hi from Denmark
« Reply #8 on: February 25, 2018, 04:38:45 PM »
Lovely build, I really like the tank colour. What size tyres are you running? Im curious about the rear tyre but the front looks like a tight fit with the fender  :riding:
  • Scotland
Offline Enfield
Re: Hi from Denmark
« Reply #9 on: February 25, 2018, 04:47:26 PM »
Thank you
 I run Heidenau Scout - front is 4.00-18 , rear is 140/80-17
 Front tyre is thight - plan to make some brackets to lift the front fender a bit.
Tank colour is German WW2 ... “feld grau”.
 Regards
Christian
  • Copenhagen
Offline DJEwen
Re: Hi from Denmark
« Reply #10 on: March 01, 2018, 08:01:14 AM »
German WW2 colours.. ballsy.
Nice build, keep us posted on the riser brackets.
Dave
  • Scotland
Re: Hi from Denmark
« Reply #11 on: March 01, 2018, 08:13:11 AM »
There's also a lesson in pattern-making in one of those photos, too. :giggles
It's a good-looking machine for sure, Enfield.
Offline Enfield
Re: Hi from Denmark
« Reply #12 on: March 01, 2018, 04:04:54 PM »
Thanks @Laitch and @DJEwen  will post when I get round to making a bracket of some kind.  I have just finished a base for a new seat ( the off the shelf one I got is not a perfect fit) Plan to have a pro to make it in full grain leather as the bags!
Regards
Christian
  • Copenhagen
Offline DJEwen
Re: Hi from Denmark
« Reply #13 on: March 02, 2018, 05:02:27 AM »
Did you get your off the shelf seat from Texavina?
  • Scotland
Offline Enfield
Re: Hi from Denmark
« Reply #14 on: March 02, 2018, 05:46:16 AM »
No from Boxerclasicas in Spain. It is ok - but I want one in full grain leather, and a better fit around the gas tank. - also allowing space for the tank mount!
Chr
  • Copenhagen
Offline DJEwen
Re: Hi from Denmark
« Reply #15 on: March 02, 2018, 06:35:08 AM »
Chr
Ahh.. never heard of them. I have a little fitment issue with mine also, its about 1/2" shy of the tank, do you know if theres any play to be able to move the tank back slightly to close the gap? The seat can't come forward any or it won't fit the step in the frame. I've not got as far as removing the tank yet so no idea whether there is any wiggle room or not, I suspect not.
I actually had to cut out the rear tank mount from the frame to allow the seat to seat properly.
  • Scotland
Offline Enfield
Re: Hi from Denmark
« Reply #16 on: March 02, 2018, 06:51:33 AM »
Ahh damn.... I wouldnt move the tank back - it kind of locks in some rubberbushes in the front - at least you would have to modify it🤨.
 What about finding something Black or whatever - not foam - but still flexible that you could cut in shape of end of seat and then glue it on the tank. It would of course need to have a closed edge that would look Good.
 That was what I thought of before deciding to build a seat🤪.
Regards
Christian
  • Copenhagen
Offline DJEwen
Re: Hi from Denmark
« Reply #17 on: March 02, 2018, 09:29:25 AM »
Regards
Christian
Hmm, yeah, it's a good idea. Im kind of on two minds what to do though, would prefer if it fitted. May have to get it adjusted slightly or look at modding the frame.
  • Scotland
Offline Enfield
Re: Hi from Denmark
« Reply #18 on: April 24, 2018, 02:31:10 PM »
Just an Update . Changed the Seat - made a plywood base and had it finished with full grain leather. It Will be a while before a Good patina develops..
  • Copenhagen
Re: Hi from Denmark
« Reply #19 on: April 24, 2018, 02:51:52 PM »
Eat more burritos. :2thumbup:
Offline Enfield
Re: Hi from Denmark
« Reply #20 on: April 24, 2018, 02:52:15 PM »
[emoji23]
  • Copenhagen
Offline DJEwen
Re: Hi from Denmark
« Reply #21 on: April 24, 2018, 03:28:24 PM »
No chance of getting a sore backside with the amount of foam in that badboy!
  • Scotland
Offline Enfield
Re: Hi from Denmark
« Reply #22 on: April 25, 2018, 05:52:57 AM »
Nope - it is build to be used!! ..... but I Think the guy who did the foam and leather was maybe a little too generous with the foam[emoji848]....at least compared to Sir Ulrich[emoji23] ....that must be a sore backside after 3 hours - but the look is unbeatable..
  • Copenhagen
Offline Enfield
Re: Hi from Denmark
« Reply #23 on: April 25, 2018, 06:50:13 AM »
And a word of Warning for those who plan to build a Scrambler.... I am 2 meters tall and with the K1100 rear spring and the new Seat .... then I Can only touch the Ground with both feet if I wear my Carolina logger boots
  • Copenhagen
Offline John Lang
  • John Lang
Re: Hi from Denmark
« Reply #24 on: April 25, 2018, 08:04:16 AM »
Re WWII German army colours: here I am sitting on a faithfully refurbished Wehrmacht bike now in the Warsaw Uprising museum.
  • Ottawa, ON Canada
  • 1987 K75C
