fuel pump wire - suggestions or confirmation?
Topic: fuel pump wire - suggestions or confirmation? (Read 3363 times)
DavidATL
^ Proficient Motobricker
January 16, 2018, 09:53:35 PM »
The installation on my fuel pump wires is cracking and leaving too much of the bare wire exposed for my comfort. Also, the wire at the pump end ring terminal has been over-flexed and a strand or two may have broken. I don't want this to break free.
I could not find wire with insulation rated specifically for in tank use. Teflon seems to have the very good oil/ gas resistance. I am planning on replacing the OEM wires with:
https://www.amazon.com/Electrical-Nominal-Voltage-Temperature-Resistance/dp/B076N2J31N
14 awg teflon coated. I will also use some sections of teflon tubing to encapsulate the soldered joints.
Anybody have alternate suggestions?
Atlanta
K75RT '92 w/ 28k miles (former bikes: '82 FT500, 80's GL500 Silverwing, 550 Nighthawk and FINALLY an '88 K75S) https://georgiaroads.wordpress.com including my #GA4corners route
The Mighty Gryphon
Administrator
Re: fuel pump wire - suggestions or confirmation?
Reply #1 on:
January 16, 2018, 10:05:34 PM »
14AWG sounds a little heavy. I would suggest nothing larger than 18AWG. You could probably get by with 20AWG.
In my garage in Marilla, NY
'91K100RS White/Blue
rbm
Reply #2 on:
January 17, 2018, 12:27:14 AM »
I've bought
16 AWG Silver Plated PTFE teflon (R) Wire Assortment
(25 feet 19 strand) from Ebay and used it on a pump repair with success. You'll need to use silver solder to connect up to the gas-tight passthrough. Also, crimp and solder the ring terminals to the other end. You can leave them bare or cover in shrinkwrap. You'll need to remove all the old solder from the lugs and clean up with copper braid before soldering on the new wires. Use short 1/2" sections of heat shrink to bind the wire pair together into a cable.
https://photos.app.goo.gl/BEsrwHyKSq8hTC5s2
https://photos.app.goo.gl/ggB5QcwGUfrm8qZt1
Regards, Robert
1987 K75 - Build Blog @
http://k75retro.blogspot.ca/
