Author Topic: Throttle assist / inexpensive "cruise control"  (Read 5869 times)
Offline beemuker
« on: January 04, 2018, 01:20:58 PM »
I had these on my Honda [that I sold]. I tried it on my K75 and it worked somewhat, but hit the mirror stalk unless angled. I remember another K I had came with a device that was on the bar end you tightened/loosened. I'm looking for something to give my throttle hand a rest on a long ride. I may order one of these, but $20 is expensive for what it is, just a piece of plastic. I don't now if I should order the 7/8 or 1" version either. my bike has the original grips and they are fatter at the inboard end. advice?
honda
https://www.amazon.com/dp/B0055QOKC8/_encoding=UTF8?coliid=ILF1EKUE4ZJGA&colid=GP0OTF909MX0&psc=1
the ones I had on my bmw looked looked this
https://www.bikebandit.com/aftermarket-parts/control-brakes/bar-ends/kuryakyn-mechanical-throttle-cruise-assist/p/45620?m=117
  • Panama City, FL
Re: Throttle assist / inexpensive "cruise control"
« Reply #1 on: January 04, 2018, 01:35:23 PM »
Sounds like a throttlemeister was on your K1, I've got one on my K75, nice thing is you can tighten it enuf not to lock it but just keep it from snapping back.  Prices start north of $100
http://throttlemeister.com/
Offline beemuker
« Reply #2 on: January 04, 2018, 01:57:00 PM »
yep, that was it.. wow, pricey, but  it looks good and works well. I don't see one for the 75
I wonder if these would work
https://www.ebay.com/itm/Throttlemeister-throttle-lock-cruise-control-for-BMW-K75-92-w-heated-grips/322936482962?hash=item4b3083ac92:g:Wj0AAOSwke9aL~3U&vxp=mtr
  • Panama City, FL
« Reply #3 on: January 04, 2018, 08:00:56 PM »
Made out of a piece of scrap aluminium angle.http://www.motobrick.com/index.php/topic,7822.msg56073.html#msg56073 A lot safer and easier to use.
Offline alexis291
« Reply #4 on: January 05, 2018, 04:20:12 AM »
Here's another variant which works well after a bit of experimentation to get the tension right.
Made from 2.5 mm spring steel wire (eBay), covered with heat shrink.
  • UK
  • K1100RS 1995
