Author Topic: flat rear rack options?  (Read 7308 times)
Offline beemuker
« on: January 01, 2018, 09:29:23 AM »
I need something flat to strap an instrument case down. something like H&b would work without the upright bar. suggestions for a K75s
http://www.accessoryinternational.com/product/hepco-becker-rear-luggage-rack-bmw-k75-k100.html
  • Panama City, FL
Re: flat rear rack options?
« Reply #1 on: January 01, 2018, 10:28:49 AM »
. . . something like H&b would work without the upright bar.
That bar could be removed. If more stiffening were needed, another tube could be TIG-welded in the lateral array, but I doubt that will be case. This model fits your bike's year.
Offline beemuker
« Reply #2 on: January 01, 2018, 11:41:15 AM »
thanks. would it have to be cut off, then ground and repainted?
  • Panama City, FL
« Reply #3 on: January 01, 2018, 12:04:07 PM »
If you have the standard rack this can be added I had some aluminium plate folded, at a angle low for the front and higher for the rear. Made them out of cardboard and worked out the angles and had a metal shop cut and fold them. After I had them done I realised that I could have had them done in one piece.They bolt to the OEM rack with 6mm screws. The front plate will have to have a curve filed into it to conform with the tail piece. I had them do three sets, one for a mate and two for me. Aluminium brackets are both 160 mm wide, front bracket 30mm high by 70mm length rear 100mm high by 70 mm length. Make them out of cardboard first and check.
Happy New Year regards Martin.
* Top Box Aluminium Mount 2.jpg (40.87 kB . 432x576 - viewed 591 times)
* Top Box Aluminium Mount 3.jpg (49.88 kB . 768x576 - viewed 582 times)
* Top Box Aluminium Mount 4.jpg (44.34 kB . 768x576 - viewed 601 times)
* Top Box Aluminium Mount 1.jpg (188.65 kB . 600x450 - viewed 599 times)
Offline bocutter Ed
« Reply #4 on: January 01, 2018, 02:19:46 PM »
What size is the instrument case?
  • Toronto, Canada
Offline beemuker
« Reply #5 on: January 02, 2018, 09:18:03 AM »
30 inches , 76 cm long. 12 " wide
  • Panama City, FL
Offline beemuker
« Reply #6 on: January 03, 2018, 11:14:36 AM »
thanks, I may look into thatand see  if I can find someone to make that for me.
  • Panama City, FL
Offline bocutter Ed
« Reply #7 on: January 03, 2018, 01:05:22 PM »
My 'kitchen' top-case is 27" wide, and has hardware that snaps onto a standard Givi E181 rack.
  • Toronto, Canada
Offline beemuker
« Reply #8 on: January 03, 2018, 05:46:00 PM »
what is the diagonal measurement. would it fit something 30" long
  • Panama City, FL
