the connections are Pin 30 = power in Pin 85 = earth Pin 86 = switch Pin 87 = power out acc 1.
This is the number codes for the DIN standard, which you find on all automotive relays after the DIN norm.
On the Narva relay number 30 is on the place where 86 should have been and vice versa.
The Narva relay is a Type B, you should have a Type A.
The Narva relay missing a spike protection which the genuine relay have.
The Narva relay have a single output (87) which should be double (87x2).....your bike should not start with
this relay.......it's something very strange happening here, unless the wiring have been modified.
