Author Topic: Temp relay problems?  (Read 3917 times)
Offline Gr-Racing
« on: December 06, 2017, 04:25:19 AM »
Well guys i got the project running but I noticed that the fan is not turning on, i had the bike on idle for 15 minuets and the fan dosent turn on
I did a few test after searching on here  but wanted to doble check
I jump the bare connector on the relay socket
Jumper A2 to 45 will bypass the temp relay and the fan should start.  fan works.
[/size]
[/size]Jumper A3 to ground and the overtemp light illuminate.
Now i did this test and got nothing to work, i had the relay plug in and tryed to ground it from the bottom and got nothing , is this the right way to do it?
[/size]Ground pin E will simulate overheating to the temp relay. The fan should start and the overtemp light illuminate.  Proves the temperature relay is functiona
[/size]
[/size]
[/size]Thanks
[/size]
  • GA
  • K75
Re: Temp relay problems?
« Reply #1 on: December 06, 2017, 04:33:24 AM »
You should jump the contacts in the socket, with the relay removed.
Check that the fan isn't seized.
Offline Gr-Racing
« Reply #2 on: December 06, 2017, 04:37:14 AM »
I made the test on the contacts and got the fan to turn on and also the over temp light to work but with the relay on i havent seen the fan work after 15 mints idle
Im thinking the relay is bad but dont have a 100% way to check it
  • GA
  • K75
« Reply #3 on: December 06, 2017, 04:47:18 AM »
Last test must be done with the relay in the socket and the engine running.
Offline Gr-Racing
« Reply #4 on: December 06, 2017, 04:55:58 AM »
Ok thank you so much for the help, i did the test with the engine off i will try again tomorrow
Thanks alot
  • GA
  • K75
Offline luman1991
« Reply #5 on: December 06, 2017, 05:18:04 AM »
Is wheels of bmw k1200rs 2001 is possible to set on my bmw k100 1986 or is hard to get it on my bike?
  • Celje Slovenija
  • Bmw k100 (86), bmw gs 1200 (17), yamaha wrf 250 (08), Honda 500 four
Offline luman1991
« Reply #6 on: December 06, 2017, 05:18:58 AM »
  • Celje Slovenija
