Author Topic: OK to run a K75RT with the lower fairing removed?  (Read 3111 times)
Offline DavidATL
« on: November 27, 2017, 05:19:14 PM »
As I progress through my coolant system maintenance, I'd like to test ride the bike without going through the hassle of putting the lower fairing back on (left, right and radiator cover removed). Other than some concerns I have about flexing the now unsupported ridgid metal front brake line, I don't notice anything of concern.
BTW, this thing was pretty dirty under all that plastic. :-(
Comments?
  • Atlanta
Re: OK to run a K75RT with the lower fairing removed?
« Reply #1 on: November 27, 2017, 08:12:01 PM »
Should be fine. Many people choose to remove the lower fairing panels to gain better airflow and reduce problems with trapped heat.
Offline schrocketeer
« Reply #2 on: January 10, 2019, 11:43:50 AM »
Is there a way to modify an '85 RT lower fairing, with the flaps/vents off of an LT, for better circulation?
Maybe, more specifically, what did the LT do to resolve the thigh toaster problem on an RT?
  • North Alabama
  • 1985 K100RT very original
Ken
