Author Topic: Fuel pump doesn't stop after prime and overflows back into tank from the top  (Read 5068 times)
Offline ccalverto
Hey - Ive changed the whole inside of the tank out on my 1991 K100 RS 4V but when i turn on the ignition the fuel pump keeps going recycling in the tank.
I've taken a video here: [size=78%][/size]
The fuel pipe to the injector rail us under pressure i just cant explain why it is coming from the top of the tank roof.
Anyone help?
  • Sydney
  • 1991 K100RS 16V mutant
That is the return from the fuel pressure regulator you see in the tank.
Offline ccalverto
Why would it be doing that?
  • Sydney
The fuel pump is on continuously with the Bricks. It does not stop start like some the FPR returns unused fuel back to the tank.
Offline ccalverto
dammit - i was hoping that was the reason it wasn't firing over!!! - thanks all for your help.
  • Sydney
I think you need to study how your bike works. Hope doesn't cut it. :giggles
Several good resources in the Repair Guidance section's master list.
Have you measured the pressurized line(injector rail inlet) with a gauge, it's possible your FPR is failing and bypassing too much fuel back to the tank, thus not having enough "push pressure" to get the correct amount of fuel thru the injectors when they open.
The fuel pump should not run continuous without the engine turning.
Older Jetronic control systems power the fuel pump when the start button was pressed, and then the pump continues when the controller detects engine rotation signal from the HES sensors.
Newer Motronic systems "prime" for about 3-5 seconds when key is turned on, then pump turns off until engine rotation is detected by the HES sensors.
