Author Topic: WTB Trip odometer BMW#6211230175 1992 K75RT  (Read 5867 times)
Offline Paul Hosticka
  • 1st. Boomer
« on: November 10, 2017, 02:18:59 PM »
Want new, used but working, or core. Need one black tumbler
  • Dayton WA USA
  • 1992 K75RT 1967 R50/2 1962 Norton ES2
I'm just along for the ride
Offline mtwhickory
Re: WTB Trip odometer BMW#6211230175 1992 K75RT
« Reply #1 on: November 18, 2017, 01:17:10 AM »
If yours isn't working I can tell you how to fix it.
  • Hickory NC
  • 1992 K75S (modded to an RT with bags, taller windshield, and standard bars)
  • 1st. Boomer
« Reply #2 on: November 18, 2017, 11:42:22 AM »
Found a core cluster with working trip and am installing today. I hate stuff that doesn't work. Anyone know about the so called self canceling turn signal circuit, mine has never worked? If it is in the cluster maybe I can swap it out.
  • Dayton WA USA
« Reply #3 on: November 18, 2017, 01:59:02 PM »
Although the post in this link doesn't answer whether the cluster is involved, it does show that a correctable defect in the switch assembly can cause failure to function. The entire thread could be of interest to you.
« Reply #4 on: November 18, 2017, 07:45:43 PM »
The path for the pulse signal is divided between the speedo itself and the turn signal relay after the
preamplifier inside the cluster.
It's a blue/green wire between the cluster and relay, check the connections and if you have signal
using a analogue meter set to milliamps.
