Author Topic: The MechaniK  (Read 83281 times)
Offline Roland
Re: The MechaniK
« Reply #100 on: March 23, 2018, 11:52:32 AM »
yes the amount of money spent so far. just wondering what an amazing build like this costs.
  • California
  • 1985 k100rt
Offline prakash
Re: The MechaniK
« Reply #101 on: March 29, 2018, 06:43:05 PM »
This build of yours is a true beauty and an engineering inspiration to all bikers who want something unique. Best of luck for rest of your build. Cannot wait to see the final outcome.
  • Maine
  • 1988 BMW K75, 1982 Honda CB900C
Offline Gabi Nicolae
Re: The MechaniK
« Reply #102 on: May 13, 2018, 09:33:42 AM »
Sorry for not answering so far, I was really busy doing other custom stuff. The exact amount of money I spent so far, cash out of the pocket is 7281 eur. Plus 325 labor hours. I'm almost finishing the bike, but I still need about 4 working days - which I don't have...
Sent from my SM-G892A using Tapatalk
  • Romania, Europe
  • Ktm 1190 Adv, Ktm 640 Adv, BMW k100 Taifun
Offline milq
Re: The MechaniK
« Reply #103 on: May 16, 2018, 02:00:05 AM »
I have to admit that I’m curious about the rear shock absorber specifications.
I have zero experience calculating spring pressures and such. Did you use a shock that is a ready-built part for a different machine? Or is it a custom unit?
  • Southern IL
  • 1988 K75S
Re: The MechaniK
« Reply #104 on: June 06, 2018, 04:53:34 AM »
Finally, first drive. Very happy with the result! :) Best chapter is the suspension, by far. Second, the geometry /drivability. The engine shall be fine tuned, as it's not running smoothly, but nothing which a vacuum tool can't fix :). Here you have some pics.
  • Romania, Europe
Re: The MechaniK
« Reply #105 on: June 06, 2018, 04:55:20 AM »
And an YouTube link.
  • Romania, Europe
Re: The MechaniK
« Reply #106 on: June 06, 2018, 07:59:03 AM »
It seems like riding it attracts the police! :giggles Thanks for the upload.
Offline DJEwen
Re: The MechaniK
« Reply #107 on: June 07, 2018, 04:39:11 PM »
Congratulations  :riding:
  • Scotland
Re: The MechaniK
« Reply #108 on: June 11, 2018, 04:27:18 AM »
And some pro photos.
  • Romania, Europe
Offline Joel_nl
Re: The MechaniK
« Reply #109 on: June 11, 2018, 06:08:00 AM »
Amazing build!   one question though :)
Why did you choose to put the rigid part in the front, and the moving (triangle) in the back?   It would seem to me the connection point in the front is a better fit given the rigid frame.
I've been planning something similar for my own BMW K75.       Using most of the Yamaha Yzf R1 linkage, and a custom made frame mount.       main difference i've been planning is (as mentioned above) to keep the moving parts close to the frame.
  • The Netherlands
  • BMW K75
Re: The MechaniK
« Reply #110 on: June 11, 2018, 11:26:28 AM »
I like this pictures :)
  • Romania, Europe
Re: The MechaniK
« Reply #111 on: June 11, 2018, 11:28:09 AM »
Hi,
There are rotating points at the both sides, there is no fix part on this system... Or maybe I didn't got the idea you want to say?
  • Romania, Europe
Offline Joel_nl
Re: The MechaniK
« Reply #112 on: June 12, 2018, 07:12:43 AM »
I mean placing the brackets like this:
In my opinion, most of the force would meet in the front, closest to the frame. my idea of the setup would give you room to weld a bigger/stronger bracket to the frame instead of having to resort to re-use the treads on the back wheel.
On the back the setup would be a bit simpler than your setup allowing for a simpler bracket that would distribute the force more evenly.
But since you've build your setup, i would love to hear your thoughts :)
PS: sorry for the small image.
  • The Netherlands
  • BMW K75
Re: The MechaniK
« Reply #113 on: June 12, 2018, 09:06:38 AM »
Feel free to post another, larger image, Joel. It will be more helpful than your current submission and should be much less effort than designing and building successful a suspension system :2thumbup: .
Offline Joel_nl
Re: The MechaniK
« Reply #114 on: June 12, 2018, 09:32:15 AM »
@Laitch, i know i should have created a larger version :)     i just did it quickly to show Gabi how i think the linkage system could also work.  (simply switching it around).
When i get cracking on my own project (hopefully starting next month) i'll do my own work-log.     just wanted to hear Gabi's thoughts on my idea since he has some experience before i do my own CAD drawings instead of a crappy photoshop mockup :)
  • The Netherlands
  • BMW K75
Offline Joel_nl
Re: The MechaniK
« Reply #115 on: June 12, 2018, 09:48:33 AM »
I upscaled my crappy mockup and highlighted the 4 key parts.       in red the bracket that mounts to the rear wheel, and the linkage that mounts to the frame
In yellow the dogbone and suspension.      i hope this makes it a bit better to see.
PS: Editing posts is disabled in this forum?
  • The Netherlands
  • BMW K75
Re: The MechaniK
« Reply #116 on: June 12, 2018, 09:55:44 AM »
It will not gonna work, for sure I would say... :))) Check the forces : when the wheel will go up, the fixed part on the diff will push against the shock. Fine. But the push/pull rod will follow the movement, so will rotate the triangles, which in turn will try to extend the shock. Which means you will have a shock that will move forward and backward, without being compressed or depressed.
  • Romania, Europe
Re: The MechaniK
« Reply #117 on: June 12, 2018, 10:17:38 AM »
More than Gabi is reviewing this forum. It's just a courtesy to others, Joel. You want a private discussion with him? Use personal messaging.
Regarding editing, you need to reach a certain post count but I don't know what that is. What I did was Preview my posts to correct them before submissions, but we all agree that accidents will happen.
 :falldown:
Offline Joel_nl
Re: The MechaniK
« Reply #118 on: June 12, 2018, 11:09:31 AM »
@Laitch, not sure if my posts are venturing in the personal discussion, please let me know if they do..
@Gabi, Thanks for you reply.    I did a simple test in 3D and almost directly saw your point :)     i changed it a bit;
  • The Netherlands
  • BMW K75
Re: The MechaniK
« Reply #119 on: June 12, 2018, 11:43:03 AM »
Please take into the consideration the fact that the fixed part on the diff is not moving up and down straight, but it's rotating, having the center point  at the gear box main bolts (where the rear transmission is bolted to the gear box). That will change your drawings a bit.
  • Romania, Europe
Offline Roland
Re: The MechaniK
« Reply #120 on: June 12, 2018, 05:18:52 PM »
As well as that. The rocker on the chassis side has to rotate and have bushings for the shock and linkage. The animation does not alow the linkages to rotate in the rocker. It would work your way and has been done before. Since the rocker is at a pivot point higher than the swingarm pivot the center of the wheel will travel in an ark so that it is constantly moving closer the the rocker pivot. The whole point of the rocket is to fix the ratio of movement so the shock actually compresses a distance enough to dampen the movement without having a crazy pressure setup. Hope this helps. :bmwsmile
  • California
  • 1985 k100rt
Re: The MechaniK
« Reply #121 on: August 16, 2018, 08:21:54 AM »
  • Romania, Europe
Offline NickHeijman
Re: The MechaniK
« Reply #122 on: August 20, 2018, 11:15:08 AM »
Bravo !
What a build, looks absolutely fantastic.
Many many many custom parts and damn bro your CAD skills are of the hook !
Thumbs up for you build, fckn love it.
Have my own build, lookup the Hedgehog project with also the rearshock horizontal.
Posting some new pictures next week, would be glad if you can help me out a little on the pressure on the frame and read linkage/bolts.
Cheers,
Nick
  • Breda
  • BMW K75S
Offline zenitramnaes
Re: The MechaniK
« Reply #123 on: August 20, 2018, 11:48:01 AM »
So dope, congratulations on the build.
  • USA
  • '85 K100rs
