Author Topic: Motor grommet set for Glass Blasting  (Read 11931 times)
Offline Aquasaxx
« on: November 01, 2017, 11:08:51 PM »
Would anyone know where I could obtain a grommet kit to plug motor. Wanting to glass blast motor
Cheers
  • Brisbane, Australia
  • 1986 K75 S
Offline Aquasaxx
Re: Motor grommet set for Glass Blasting
« Reply #1 on: November 01, 2017, 11:29:29 PM »
  • 1986 K75 S
Offline propav8r
« Reply #2 on: November 06, 2017, 12:42:02 PM »
You can get small expanding rubber plugs from your local auto parts store. They're sold in the Help aisle as emergency freeze plugs. That should do the intake and exhaust ports, and probably the water pump inlet/outlet too. Alternatively, you could just loop those together with a long hose.. I'd cap the PCV port with rubber stopper wedged in there.
The Alternator presents a bigger issue. Obviously, you can't leave it on there while you're blasting. It'll get crap all in it. I'd probably take it off and seal up the opening with some scrap sheet metal temporarily glued in with RTV or something. The starter hole can also be taken care of with an expanding plug.
Good luck. That crap gets everywhere.
  • Franklin, NC
  • 1985 K100RS, 1978 GL1000, 1972 Kawasaki H2 750
