Author Topic: K1100 help identify relay  (Read 4650 times)
Offline Deepnoizer
« on: October 13, 2017, 08:06:40 AM »
I'm working on stripped down (93) K1100 and I'm in process of cleaning up wiring a bit. I found tucked away and taped two relays by front fork I got no idea what they are.
Any idea?
  • NYC
  • K1100
Re: K1100 help identify relay
« Reply #1 on: October 13, 2017, 08:37:24 AM »
I'm guessing they're headlight relays.  If you pull them out, I'll bet that your headlight won't work.  They are there to keep the headlight current from burning up the dimmer switch on the left handlebar.
Offline Deepnoizer
« Reply #2 on: October 13, 2017, 08:38:35 AM »
Thank you I will test that later.
  • NYC
  • K1100
« Reply #3 on: October 13, 2017, 08:54:10 AM »
The relays is for the windscreen lifter motor.
« Reply #4 on: October 13, 2017, 04:19:28 PM »
+1
I have them on both my LT's.
Offline Deepnoizer
« Reply #5 on: October 13, 2017, 04:25:07 PM »
So they can safely go if my windshield is gone I assume ?
  • NYC
  • K1100
« Reply #6 on: October 13, 2017, 05:54:01 PM »
What do believe might happen if you remove them?
