Author Topic: Spline lube Honda M60  (Read 3630 times)
Offline Faghurts
« on: October 07, 2017, 05:49:51 PM »
Does any one know if the Honda M60 is still available?
It seems likes like part number changed over to M-77. Is this correct?
Will this stuff work: [size=78%]https://www.amazon.com/Honda-HN-08798-9010-MOLY-PASTE/dp/B0083BWUYW[/size]
Thanks in advance!
Drew
  • Milwaukee,WI
  • '87 K75C
Re: Spline lube Honda M60
« Reply #1 on: October 07, 2017, 06:09:24 PM »
Honda Moly 60 is now known as Honda M77 Assembly Paste and can also be obtained from Subaru dealers as M77 assembly paste.
Offline TX brick
« Reply #2 on: October 08, 2017, 07:06:26 AM »
I read on one of the forums that a guy who tried M77 reported that it separated with heat. He used it anyway and said it didn't stay on the splines and he saw wear later.
Ron
91 K75RT
Belton Tx
« Reply #3 on: October 08, 2017, 08:55:41 AM »
The use of M77 is widely reported with satisfaction. It is fair to say that in some cases, thorough cleaning of the splines is neglected and that would cause adhesion failure. A thin film of paste carefully applied to a clean surface is all that is needed.
