Author Topic: Where do these parts go??????  (Read 10633 times)
Offline jmcmul2
« on: October 01, 2017, 07:51:29 PM »
So a friend gave me an 87 K100RS disassembled and basically in pieces in boxes. I successfully repaired and reassembled the bike, no small feat since I didn't take it apart! Problem is I have three parts left over, two strange black plastic covers, and this little spring doodad. So any of you K experts have an idea where these go? Thanks a million in advance. Pictures attached, John.
  • Louisiana
  • 1987 K100RS
Re: Where do these parts go??????
« Reply #1 on: October 01, 2017, 07:57:59 PM »
no idea, but the plastic things might have a bmw part# you could google
« Reply #2 on: October 01, 2017, 08:08:41 PM »
My guess, the upper pic looks like it could be a non-bmw retaining clip for the fuel tank.
The lower pic looks like left and right dash panels for holding gauges.
« Reply #3 on: October 01, 2017, 08:24:13 PM »
The clip is possibly a home made one for holding the air cleaner housing together.
« Reply #4 on: October 01, 2017, 09:12:17 PM »
The top pic is a mirror retaining clip - not sure about the others
Offline jmcmul2
« Reply #5 on: October 01, 2017, 10:20:49 PM »
Thanks, I tried the number on the back and came up empty. It was hard to read, maybe I will try again. John
  • Louisiana
  • 1987 K100RS
Offline jmcmul2
« Reply #6 on: October 01, 2017, 10:24:41 PM »
Any idea how does the mirror retaining clip attaches? I can't see it in either a parts breakdown or in my Clymer. John
  • Louisiana
  • 1987 K100RS
« Reply #7 on: October 01, 2017, 11:31:08 PM »
mystery partly solved, #7 on bob's bmw parts fiche
« Reply #8 on: October 02, 2017, 02:07:41 AM »
Fits in the grove on the balljoint stub.....to secure the mirror glass.
Offline jmcmul2
« Reply #9 on: October 02, 2017, 08:28:57 AM »
Thanks, I had a inkling that it was something to do with the mirror. Do I just clip it on the mirror before I pop it in to the ball joint? It is not really clear what its function is. And in case you missed it, I am really appreciate your help! John
  • Louisiana
  • 1987 K100RS
« Reply #10 on: October 02, 2017, 08:32:03 AM »
No it goes on the other side of the ball joint, the idea being that the clip holds the mirror in place on the other side where the tip of the mirror ball socket pokes through.  This is for RS mirrors BTW, I know LT ones are different
Offline jmcmul2
« Reply #11 on: October 02, 2017, 08:33:57 AM »
Thanks for the help on the mystery parts. I now see the two strange plastic covers go under the fairing and actually attach at the main bolts holding the fairing! Burried.... yuck, at first glance it appears that I will have to remove the fairing to put them in. Oh well, a rainy day here in Louisiana. Thanks for all the comments and guidance, John.
  • Louisiana
  • 1987 K100RS
Offline jmcmul2
« Reply #12 on: October 02, 2017, 10:38:14 AM »
Hey Poserbricker. I am sorry to be such a bother, but I have the mirror and clip in my hot little hand..... and I really don't have a clue what to do with that clip. The ball on the back of the mirror clearly snaps in to the socket on the light body, but what the heck do I do with that clip! Sorry if I appear clueless. Any other advice would be most appreciated. John.
  • Louisiana
  • 1987 K100RS
« Reply #13 on: October 02, 2017, 11:12:24 AM »
OK what you do is unscrew and remove the orange indicator lens.  The you can see down inside where the mirror glass ball comes out the other side.  That is where the clip connects.  It is hard to see but I have attached a couple of photos.
Hope it helps
Offline jmcmul2
« Reply #14 on: October 02, 2017, 11:16:41 AM »
Thanks a million. You are the champ!
  • Louisiana
  • 1987 K100RS
« Reply #15 on: October 02, 2017, 11:19:02 AM »
You are very welcome -I scratched my head a lot as well before finding out where they went!
« Reply #16 on: October 02, 2017, 08:56:56 PM »
I have those hairpin clips on my 1992 RS.  When purchasing spare mirrors I have found that there are two different styles of mount for the glass.  Later models used that %^$@(*& clip that is a royal pain in the ass while early models had a pair of clip wires permanently installed in the socket.  Look in the hole the post goes into.  If you can see a pair of parallel wires, you probably don't need the clip.  Just push it in until it locks and you should be good to go.
Your 1987 mirrors may have that earlier version and don't require the hairpin clip.  If they are the early version not only will you not need the hairpin, but it can't even be installed in the groove in the post on the glass.  I found that out the very hard way.
Offline jmcmul2
« Reply #17 on: October 03, 2017, 07:10:33 AM »
Thanks for the input. Another poster sent me some pics showing how the clip attaches. Doesn't seem that secure, hopefully my mirror won't fall out! Again, thanks for the input.
  • Louisiana
  • 1987 K100RS
« Reply #18 on: October 03, 2017, 07:26:45 AM »
Looks like a roach clip and an ashtray to me.
« Reply #19 on: October 03, 2017, 07:30:34 AM »
The clips are not hugely strong and mirrors have been known to fall off - both the entire mirror housing and just the glass.  I have two tethers installed on mine, one for the housing and one for the glass.  They have proved their worth more than once already and since RS mirror glass and indicator lenses are becoming as rare as hens teeth I wold recommend doing something similar.
Offline Batkinson
  • Dumbass Level 1
  • retread rider....KZ650 30 yrs ago,85 BMW K100 now
« Reply #20 on: October 11, 2017, 10:24:42 AM »
the two plastic parts, Chaos' #7 are part of the radiator trim right and left sides......two screws to mount
  • Hampton Roads, VA
  • 85 K100, 92 K75
85 K100, eng#F3M698745K335840559, FRAME: WB1051401F0050557,
92 K75  VIN:WB1057105N0133981
Offline jmcmul2
« Reply #21 on: October 11, 2017, 10:53:16 AM »
Thanks, I finally figured them out! They are quite hidden from view in front of the tank. I really don't know what function they actually serve, but I have put them in place. Thanks again for everyone's help.
  • Louisiana
  • 1987 K100RS
