Author Topic: LED Strip - Brake Light Not Coming On?  (Read 2845 times)
Offline 85-K100-Cafe
« on: September 21, 2017, 09:42:56 AM »
Hello, i am trying to run a LED strip at the rear of my 85 K100. I am currently running a Signalminder SM-6 relay for the turn signals. Issue i am having is that the brake light isn't coming on when i press the front or rear brakes. The turn signals and running light are functional on the LED strip. I tested the LED strip by placing the ground to the negative on the battery, connecting a test light to the positive of the battery and testing each wire on the LED strip. When i test the LED strip with the test light each of the lights on the LED strip work including the brake light so i know there is nothing wrong with the LED strip. Is there a certain modification i need to do on the motorcycle to running LED lights?
  • New Haven, CT
  • 1985 BMW K100
