Author Topic: Fuel sender unit  (Read 7362 times)
Offline Dbarcle1@gmail.com
Fuel sender unit
« on: September 19, 2017, 04:54:13 AM »
I am trying to repair a broken fuel sender unit on my 84K100RS,(the plastic one) have tried several adhesives the latest being a JB weld product. Nothing seems to work, the unit itself cannot be replaced at least here in Australia. Without a solution this bike is destined to be an expensive white elephant for me. Thanks if anyone can help, cheers David
  • Betley, Australia
  • K100RS
Re: Fuel sender unit
« Reply #1 on: September 19, 2017, 05:23:38 AM »
Post some pictures of the part in need of repair. Then an inmate might be able to come up with a solution.
« Reply #2 on: September 19, 2017, 06:05:08 AM »
Ok I'll do that asap, thanks
  • Betley, Australia
  • K100RS
« Reply #3 on: September 19, 2017, 06:23:27 AM »
Thanks but wrong ones, wait I'll send a pic. David
  • Betley, Australia
  • K100RS
« Reply #4 on: September 19, 2017, 06:52:45 AM »
Watch this space, 9pm here & I'm not home so will post info soon. Thanks for responding.
  • Betley, Australia
  • K100RS
Offline jay1622
« Reply #5 on: September 19, 2017, 08:52:06 PM »
 :popcorm
Early reference for potential source... http://www.euromotoelectrics.com/
  • Charlotte
Offline Blue
« Reply #6 on: September 20, 2017, 04:33:34 AM »
I might have one.  What is the part number?
  • Stovepipe Wells CA
  • 1995 K1100RS
« Reply #7 on: September 20, 2017, 04:42:21 AM »
« Reply #8 on: September 21, 2017, 03:00:41 AM »
Yes that's it, can't seem to send a pic of my own
  • Betley, Australia
  • K100RS
« Reply #9 on: September 21, 2017, 08:24:46 AM »
I think I have sorted this phone, here's 2 pics of my broken sender.
  • Betley, Australia
  • K100RS
« Reply #10 on: September 21, 2017, 08:27:27 AM »
And the other one
  • Betley, Australia
  • K100RS
« Reply #11 on: September 21, 2017, 08:22:31 PM »
It case you can't fix the sender, I wonder if a later tank swap is possible. I know the early ones were secured by a bolt, but besides that does any one know whether a conversion is possible with minimal changes. Dbarcle you might also want to try the BM shop PH (07) 3356 6128.   http://bmshop.com.au/
Offline bmwpyro
« Reply #12 on: September 21, 2017, 09:28:56 PM »
I'm wondering what is wrong with the sender that would cause non operation of the k100? so far I don't see it stated in this thread.
could be very obvious to everyone but me :D
  • Azusa, CA
  • 1985 K100RS, 1990 K75S
Always Learning...
Always something new to learn about riding and Kbikes...
"Viam inveniam aut faciam"
« Reply #13 on: September 22, 2017, 12:56:51 AM »
Sender also supplies power to fuel pump & prevents fuel pissing out the bottom, yes tank change I have considered but make that last option
  • Betley, Australia
  • K100RS
« Reply #14 on: September 22, 2017, 01:41:11 AM »
Try the BM shop, he is hard to get on the phone as he is a one man show. Might have to try multiple times, if you are unsuccessful in contacting him let me know and I'll ride down there.
Offline bmwpyro
« Reply #15 on: September 22, 2017, 01:58:42 AM »
oh I see it now, I thought at first that was a clamp type.
is that some form of plastic? if that is plastic then you can try to reweld it. you need to find out what kind of plastic it is.
you can reweld it all or you can reweld enough to provide strength and structure and use plastic epoxy (Loctite?) to fill in the rest.
the process is similar to metal welding...  I suggest you test it out on something first til you are comfortable doing it. its a pretty handy skill for other things.
suggest to use a jig to hold it in place then weld away. pls watch the second link for safety considerations also.
here are a few videos to start you off
https://goo.gl/Zikcoj
https://goo.gl/jTwC5H
https://goo.gl/A9wuCM
HTH, Good Luck.
  • Azusa, CA
Always Learning...
« Reply #16 on: September 22, 2017, 09:43:47 AM »
What does a "clamp type" clamp? Visualization here is illusive this morning.
Offline bmwpyro
« Reply #17 on: September 22, 2017, 02:14:05 PM »
i didnt know what it was called... :yes but after looking online, i think its called a compression fitting. a cobbled visual is attached.
i hope dbarcle1 can fix it.
  • Azusa, CA
Always Learning...
« Reply #18 on: September 28, 2017, 03:21:43 AM »
Not sure what I'm supposed to do with that, can't block it off, I was kinda hoping someone had a 2nd hand one on offer, that might be my only fix
  • Betley, Australia
  • K100RS
« Reply #19 on: September 28, 2017, 04:09:25 AM »
Offline bmwpyro
« Reply #20 on: September 28, 2017, 04:12:17 AM »
you can try motorworks.co.uk and see if they have one on stock? price seems reasonable...
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=BA_10_40_KA_60_50_CA
or maybe someone can comment if a later tank will work?
  • Azusa, CA
Always Learning...
