Author Topic: Fuel Tank Heat Shield  (Read 10474 times)
Offline duckytran
« on: September 14, 2017, 12:27:38 PM »
Any recommendation on an aftermarket product to add heat shield to a K75 tank? I recall seeing a thread where an aftermarket product was being applied to the bottom of the tank.
  • Austin, Texas
  • 1993 K75, 1981 R65
Re: Fuel Tank Heat Shield
« Reply #1 on: September 14, 2017, 01:13:29 PM »
you can take your tank to a ceramic heat shield applicator and have them do just the bottom of the tank...
ride dangerously...
Offline duckytran
« Reply #2 on: September 14, 2017, 01:31:52 PM »
ride dangerously...
Thanks, but I recall someone using an off the counter product that has adhesive on one side. You can simply cut to shape and apply it. Prob a cheaper solution.
  • Austin, Texas
« Reply #3 on: September 14, 2017, 04:43:01 PM »
That'll also protect it from the negligent discharge of a cosmic ray-gun.
Offline BrickMW
« Reply #4 on: September 14, 2017, 04:53:49 PM »
  • Huntsville, AL
  • 1986 K75c
Offline BrickMW
« Reply #5 on: September 14, 2017, 05:14:08 PM »
Try Thermo-tec
EDIT **This product is NOT rated to protect against cosmic ray-gun discharge - be it negligent or otherwise...** :yes
  • Huntsville, AL
  • 1986 K75c
Offline duckytran
« Reply #6 on: September 14, 2017, 05:22:52 PM »
Try Thermo-tec
I saw that and may end up using it. I thought there's something out there a little thicker in insulation.
Thanks.
  • Austin, Texas
« Reply #7 on: September 14, 2017, 06:18:43 PM »
Search for Johnny Blanket.  This is basically using a roll of thermal blanket for HVAC applications from Home Depot and cutting it up to place under the tank.  This deflects the engine heat away from the tank and keeps the fuel cooler.
Offline Blue
« Reply #8 on: September 14, 2017, 07:04:08 PM »
I am running Phenolic-Impregnated Carbon Ablator on my K1100RS.
  • Stovepipe Wells CA
  • 1995 K1100RS
Offline alexg
« Reply #9 on: September 14, 2017, 07:27:04 PM »
Search for alumina blanket insulation with Foil; There are several options. I like alumina instead of glass fiber due to EHS considerations.
  • Michigan
Alex G.
Offline duckytran
« Reply #10 on: September 14, 2017, 09:17:12 PM »
Your K1100RS hasn't blown up like some of the earlier SpaceX rockets?  :yes
  • Austin, Texas
Offline jay1622
« Reply #11 on: September 14, 2017, 11:16:24 PM »
I've got two layers of this under my tank. Easy to work with, easy to cut, the adhesive works very well, and it keeps its shape.
Thermo-Tec 13575 12" X 24" Adhesive Backed Heat Barrier https://www.amazon.com/dp/B00029KC2K/ref=cm_sw_r_cp_tai_Ew0UzbZQCFJ1H
  • Charlotte
Offline duckytran
« Reply #12 on: September 15, 2017, 08:41:39 AM »
Thanks Jay. I'm heading down that same path. Looks like it's the most cost effective option.
  • Austin, Texas
Offline jay1622
« Reply #13 on: September 15, 2017, 01:04:13 PM »
FWIW... Get more than you think you'll need, and clean the underside as absolute best you can. It will fall if you don't, and serve as a blanket for an already-hot motor.
  • Charlotte
Offline duckytran
« Reply #14 on: September 16, 2017, 01:26:08 AM »
Thanks for the advice Jay.
  • Austin, Texas
