K75 fuel pump
Topic: K75 fuel pump (Read 4408 times)
TX brick
^ Motobrick Curious
K75 fuel pump
September 13, 2017, 12:14:43 PM »
91 K75RT. Need a fuel pump. What is the latest on the Chinese ones that are a direct copy and came out a while ago? Also looking into the car pumps that require shims to fit.
Ron
91 K75RT
Belton Tx
johnny
TrailBrakingThrottleWhacker
Re: K75 fuel pump
Reply #1 on:
September 13, 2017, 12:37:46 PM »
id skip the whack and go with...
http://www.euromotoelectrics.com/category-s/1958.htm
ride dangerously...
Martin
Re: K75 fuel pump
Reply #2 on:
September 13, 2017, 02:08:34 PM »
TX I am currently running an OEM copy as a experiment, for $36.00 Au I was willing to give them a go. I do however carry my OEM one in the tail, and I was informed that many fail out of the box. I have currently got 1000 K's on it no problems so far, but early days. I did a bit of research when I decided to go with a Chinese pump and went with a manufacturer. Chrisguzzi is also running one and it is different to mine, his has got a warranty for what it's worth. For more information see this post
http://www.motobrick.com/index.php/topic,10054.msg85798.html#msg85798
If you go Chinese be aware that there are heaps of Chinese copies out there, and some will probably fail some not. If you want to play it safe I'd go with Jo's suggestion.
North Lakes Queensland Australia
1992 K75s Hybrid, Lefaux, Vespa V twin.
TX brick
^ Motobrick Curious
Re: K75 fuel pump
Reply #3 on:
September 13, 2017, 03:17:28 PM »
I don't want to spend big dollars. I remember someone sold shim kits to go with smaller auto pumps, but I can't find any now.
Ron
91 K75RT
Belton Tx
Martin
Re: K75 fuel pump
Reply #4 on:
September 13, 2017, 03:45:21 PM »
Depending on the diameter some inmates have used submersible fuel line to take up the slack. Or look up fuel resistant rubber on the net. I have also amended my previous post so that you can see the post on non OEM pumps.
stokester
^ SuperNatural Motobricker
Re: K75 fuel pump
Reply #5 on:
May 04, 2018, 02:18:18 PM »
This is where I look first ->
https://www.beemerboneyard.com/16121461576n.html
Yorktown Virginia
'94 K75S Dakar Yellow - '93 K75S Seiden Blau - '91 R100RT Bermuda Blue- '78 R100S Smoke Red
K75 fuel pump
